Old 09-24-2014, 10:50 PM   #21 (permalink)
Growin a stash
What's the secret for those of you who've had a clutch last over 200k miles? Clutch in when idling?
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
Old 09-24-2014, 11:23 PM   #22 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
No. Don't let it slip any more than necessary when taking off from a stop and rev-match on upshifts and downshifts. Control your speed with the throttle; not the clutch. (or the brakes).
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 09-25-2014, 08:32 AM   #23 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
There's no secret, as such. You just kind of pay attention to your driving.
Oh, and no rally starts.
Transmission type Efficiency
Old 09-25-2014, 12:38 PM   #24 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Clutch lining material is similar to brake pad lining material, and just like when using the brakes, you wear off some of the lining each time you slip the clutch. I consider both of these materials to be slow use consumables when operating the car. The secret to long clutch life is to minimize the amount you slip the clutch, the same as you get long brake life by minimizing the amount you use the brakes. When coasting or idling at a stop, I will usually keep the clutch pedal pressed down unless the coast or light is over a minute and then I will release the clutch pedal with the gears in neutral.
aerocivic.com
Old 09-25-2014, 12:44 PM   #25 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Don't hold the clutch in while idling. Shift to neutral and let it out.
The thrust bearing doesn't get regular lubrication, it's lubricated by a couple of teaspoons' worth of grease and that's it. Holding it in subjects it to unnecessary wear.
When engaging, keep slippage to a minimum. To get started, I goose the throttle a tiny bit to speed the engine, then engage as the revs drop back to idle. The extra kinetic energy is enough to get the vehicle moving, and I let the engine and tranny match up without any extra loading beyond that. Then I add gas.
Your mileage may vary. Too small an engine and that method might not work. It sure doesn't with the Honda, yipes.
Old 09-25-2014, 02:17 PM   #26 (permalink)
90 day: 51.82 mpg (US)
Learn clutchless shifting!
( Then replace your synchros instead of your clutch disc? )
Cobb (09-25-2014)
Old 09-25-2014, 03:29 PM   #27 (permalink)
Master Novice
elhigh's Avatar
^^Bad Metro! Bad!
Old 09-25-2014, 03:46 PM   #28 (permalink)
Mirage 5-speed drivers are beating the automatic too (CVT)
Sorry!
Back to the original topic, here's some more grist for the mill:
Of 60 Mitsu Mirage 1.2L owners tracking fuel economy on MirageForum.com, the manual drivers are beating the CVT drivers, despite the CVT's better EPA ratings:
  • CVT (27 cars): 42.1 MPG (US) = 5.6 L/100 km
  • 5-spd (33 cars): 44.2 MPG (US) = 5.3 L/100 km
Source.
The CVT is EPA rated 40 mpg (US) combined. The 5-speed is rated at 37.
Note: there's one hard core hypermiler/EcoModder member -- 3dplane -- in the 5-speed group skewing the result (he's averaging 63 mpg US), but even when you omit his results, the manuals are still ahead.
Old 09-25-2014, 05:30 PM   #29 (permalink)
Did Baby Prelude (Roheryn) just need synchros? After my third clutch replacement, I started shifting using just the accelerator, not the clutch, until one day I could not shift, and then she was towed because I "abandoned" her.
I really feel like there are not any skills that I can master to 100%. Walking? No, trip for no reason. Breathing? No, sometimes try to inhale or exhale twice in a row. Drinking water? That one can be life-threatening.
I will skip the story, but some things are not worth the time to achieve 100%
Old 09-25-2014, 08:56 PM   #30 (permalink)
I tend to operate the clutch similar to how an auto does. I relie on it slipping for smooth launches, then release and floor the throttle. If I am out at 3 am I just release the clutch at idle and roll off. If I am in rush hour I release at 3 grand and go.
I havent worn out a clutch myself, but many Ive replaced are because of either an engine oil seal leak, tranny seal leak or just because you are inside that part of the vehicle replacing a throwout bearing, flywheel or pressure plate.
Now pressure plates with broken springs and flywheels with chewed up starter gears is another story.
LinkBacks (?)
LinkBack to this Thread: https://ecomodder.com/forum/showthread.php/manual-vs-automatic-transmission-mpg-showdown-nissan-micra-30059.html
Posted By For Type Date
Yes, 28+ mpg isn't a dream!!!! - Page 13 - Dodge Cummins Diesel Forum This thread Pingback 06-05-2017 12:59 PM
Auto vs Manual - Micra-Forum.com This thread Refback 10-05-2015 02:11 PM
