Old 08-22-2022, 02:34 AM   #61 (permalink)
Originally Posted by jakobnev View Post
Best of both worlds(?), the automated Manuel transmission
Single-clutch AMTs were unsuccessful for cars in my country, even though it's a more popular option for commercial trucks than conventional automatics. Odd enough, some bus frames are offered with the option for an AMT, yet it's not so favored by fleet owners who prefer manuals whenever it's still allowed or go for a conventional automatic whenever it's mandatory.
Old 08-22-2022, 03:02 AM   #62 (permalink)
Automatic transmission vehicles cost less to manufacture than manuals.
You've said that a couple of times. Can you provide a source?
Traditional torque-converter automatic gearboxes are quite complex, what with planetary gearsets and immensely fussy shift valve bodies. Manuals have individual paired gears, and the shifting mechanisms are just sliding forks and rods.
CVTs do seem to be much simpler and probably less expensive to build.
The Following User Says Thank You to some_other_dave For This Useful Post:
aerohead (08-25-2022)
Old 08-22-2022, 08:17 AM   #63 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
From what I understand, the cost to build a car is mostly dependant on how many they can make. It costs money to design, test and make all the production line tools for a car or car part. If they can make and sell a few million the price will be way cheaper than if they make just 3.
The same is likely true of automatics and manuals. Manuals haven't changed much, so I would guess that for the same volume, manuals are actually cheaper. But it makes sense to me that because automatics are so popular and very few buy manual transmissions that it costs more per transmission to make a few manual gear boxes for the 6 and a half people in the USA that like to drive a stick shift than it is to make a hundred thousand automatics for everyone else.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
some_other_dave (08-29-2022)
Old 08-23-2022, 02:05 AM   #64 (permalink)
CVTs may have a lower production cost, and eventually a more compact size in proportion to the gear-spread, as advantages compared to a more traditional automatic transmission, yet they're not so well-suited to higher torque inputs or heavier vehicles. When it comes to manuals, they still tend to be cheaper to manufacture at least than a traditional automatic. And so are the AMTs, even with the addition of the electronic controls and actuators, and a single clutch is also cheaper than a torque converter, yet it will require a replacement once in a while.
Old 08-23-2022, 04:23 PM   #65 (permalink)
CVTs...
Unless it's a torodial CVT.
Joggernot (08-23-2022)
Old 08-25-2022, 02:38 PM   #66 (permalink)
source
Bob Lutz ( former CEO of General Motors Corp.) wrote about it in one of his 'Go Lutz Yourself' columns in ROAD & TRACK, or MOTOR TREND.
Old 09-09-2022, 06:46 AM   #67 (permalink)
IIRC the only applications for toroidal CVTs were some JDM full-size Nissan sedans.
Old 09-09-2022, 09:23 AM   #68 (permalink)
I was looking at the 2022 Toyota Sienna minvan. It gets 36mpg combined and has a CVT of sorts (Toyota's hybrid driveline). Those should be very robust.
Old 09-11-2022, 10:06 PM   #69 (permalink)
Toyota's HSD doesn't rely on a CVT properly said, as it relies on the electric motors to emulate the operating principle of a CVT.
Old 09-12-2022, 12:12 AM   #70 (permalink)
CVEMG: Continuously Variable Electric Motor-Generators.
