Old 09-13-2022, 09:23 AM   #71 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
Sequoia - '04 Toyota Sequoia Limited
90 day: 17.51 mpg (US)
Originally Posted by Isaac Zachary View Post
I was looking at the 2022 Toyota Sienna minvan. It gets 36mpg combined and has a CVT of sorts (Toyota's hybrid driveline). Those should be very robust.
36mpg/36mpg/3500lb towing capacity. That thing is badass.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 09-13-2022, 02:38 PM   #72 (permalink)
Dark Egg - '12 VW Touraeg
I've heard them called ECVT as well. No bands or clutches at all. I think they may be the most reliable transmission ever even compared to a manual which will need a clutch or 2 over it's life. They use them in the newer Toyota hybrids and the newer Ford hybrids and the Pacifica hybrid.
https://youtu.be/hHU5xFOBcsU
Old 09-14-2022, 12:03 PM   #73 (permalink)
Everything old is new again (includes regenerative braking).
justacarguy.blogspot.com/2016/02/the-owen-magnetic-transmission-electric.html
I wonder about what that is strapped to the steering column. Electric power steering?
Maybe that explains this clip from 1923?
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 09-16-2022, 07:36 PM   #74 (permalink)
Most likely.
