Old 05-08-2011, 11:38 AM   #141 (permalink)
Pardon the newb question, but if a warm air intake is a good idea, why do cars with turbos have intercoolers? Should we do a partial block of intercoolers to raise the charge temp? I understand the need to reduce the risk of detonation...
Old 05-08-2011, 11:43 AM   #142 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
A turbo can quickly reach 1300°... Hot.
Put a temp sensor in the intake stream before and after the intercooler, and you'll see why its there. For low boost, they're not always necessary.
Old 05-08-2011, 12:03 PM   #143 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.64 mpg (US)
What he said. Boost creates a LOT of heat. Air gets hot when you compress it. Naturally aspirated cars are not heating the incoming air in any way, except possibly a small amount of heat soak in the intake tubing under the hood.
Old 08-14-2011, 07:15 PM   #144 (permalink)
The only people I know that widely use a non-intercooled turbo are the 6.5L chevy diesel guys. I have read posts where they say 160-180'F is a normal IAT for them when rolling down the highway. A few have seen IATs peak at 300'F on hot days while towing on a hill climb.
Also I noticed the wiki had barely been up dated in the last 6 months, until I got ahold of it.
Old 08-14-2011, 07:39 PM   #145 (permalink)
...beats walking...
...when air is compressed, it rises in temperature, so 100ºF incoming air (before the turbo or compressor) can exit at much HIGHER (10X) temperature.
...the purpose of the "intercooler" it to remove as much of that "increased" air temperature as possible before the air is "stuffed" into the cylinders.
Old 08-15-2011, 07:29 AM   #146 (permalink)
In a diesel you want to get as much air mass stuffed into the cylinder as possible to run efficiently at any speed.
That is why I plan to run an intercooler and water injection on my diesel.
Water injection will be my next wiki after the articles printed in this months in "dieselpower magazine" become free for viewing on the internet. That one article is going to be my main "external link".
Old 10-16-2011, 02:16 AM   #147 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Question Thinner differential oil?
From the "65+ Efficiency Mods" page:
Synthetic transmission/differential oil
Reduces friction between gears leading to less energy being absorbed as heat into the oil. Also increases parts life. Again, most effective for vehicles in cold climates, since the viscosity of conventional lubricants increases as ambient temperature drops.
There are a few threads that discuss synthetic or lower-weight transmission oil. Has anyone experimented with thinner oil in the differential of a RWD car?
Old 11-17-2011, 07:17 AM   #148 (permalink)
I have; I every case, I found it made the vehicle quieter and in my informal coastdown tests it showed an improvement in mileage.
Old 12-26-2011, 09:42 PM   #149 (permalink)
Great Compilation!
Old 12-26-2011, 09:50 PM   #150 (permalink)
super stock drag racers run ATF in their rear differential. It EATS bearings and ring and pinions.
5-30 engine oil is the minimum I would run, and I sure would not run even that if I were towing with the vehicle.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
