Old 11-01-2014, 09:01 PM   #81 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Mazda MX6 Day 107 Video 031 Oct 14 2014
Discuss tying battery box to supports inside car
Open the box on my new throttle assembly
Connect throttle to netgain industrial .. but don't get the calibration done today
Mazda MX6 Day 107 Video 031 Oct 14 2014 - YouTube
Old 11-02-2014, 01:25 AM   #82 (permalink)
Contour the bottom of the box so it fits the contour of the sheetmetal. Then instead of restraining the box laterally, the bolts just have to apply clamping pressure.
Can you use the inner seatbelt mounts?
Old 11-02-2014, 12:31 PM   #83 (permalink)
The edges of the sheet metal are not very smooth. That can be fixed with a bit of time and effort.
But I'm not sure there is much structure there. The sheet metal is thin. You can flex it by pushing laterally.
The inner mounts are almost covered by the base. I may be able to bolt the rear of the battery box to the inner mounts with a bracket of some sort.
Old 11-02-2014, 12:39 PM   #84 (permalink)
Mazda MX6 Day 111 Video 032 Oct 18 2014
Work through setting up the Netgain Industrial controller with the throttle assembly
But it does not work for me
Mazda MX6 Day 111 Video 032 Oct 18 2014 - YouTube
Continue trying to get the Netgain Industrial controller to work with the throttle, the contactors, and the pre-charge
There are error codes to troubleshoot
Mazda MX6 Day 111 Video 032 2 Oct 18 2014 - YouTube
Old 11-02-2014, 12:46 PM   #85 (permalink)
Absent a picture of the bare sheet metal: The brackets could be contoured to a shape that would spread the contact with the thin sheetmetal over as wide an area as possible and then the battery box would bolt to them.
My plan is to weld the battery box to a 4-point roll bar.
Old 11-02-2014, 11:03 PM   #86 (permalink)
The videos show the sheet metal hole. I know that watching the videos is boring and a struggle, so here are a couple of pictures.
No offense, I guess I'm not convinced that it would be strong enough. I'll bolt the box to my aluminum frame (rev 2, after I finish messing around with the 2 x 4s). It's me that will be in front of that battery box in an accident and I'm doing everything I can to make sure it does not crush me.
I'm not welding anything to the frame of the car.
The roll cage sounds like a great idea. I have not investigated whether a roll cage will fit in my car.
ID:	16254   Click image for larger version
ID:	16255   Click image for larger version
Old 11-03-2014, 10:48 AM   #87 (permalink)
Mazda MX6 Day 112 Video 033 Oct 19 2014
It WORKS!!!
Let's walk through what you should see if you have a Netgain Industrial controller. Signals, voltages, some unplanned troubleshooting
This is what it looks like when it's working
Mazda MX6 Day 112 Video 033 Oct 19 2014 - YouTube
Shut down the system and start back up
A bit of a repeat
go through the lithium pack
Go through the switches
Mazda MX6 Day 112 Video 033 2 Oct 19 2014 - YouTube
Old 11-03-2014, 02:12 PM   #88 (permalink)
Forget everything I said. I'll admit I've been skimming the videos.
I'll go with 'roll or flange the edges of that opening and gusset the corners.'
That's not a body-on-frame car, is it? I think roll cages are generally welded in.
Old 11-03-2014, 04:01 PM   #89 (permalink)
I would be surprised if anyone actually watches even one of my videos end-to-end. They are detailed, repetitive, and I obviously I don't script what I do. They are more for me, video notes, cleaned up a bit so that someone else can get something out of it. I now have *5* subscribers ... 5 more than I ever expected.
Rolling the edges sounds easier than filing them. Maybe that's just because I don't know what's involved in rolling the edges? Gussets are like rounding out the inside corners, right? That sounds like it will still require filing.
I don't think so. The frame appears to be shaped steel that is spot-welded to lighter gauge steel on the floor and around the pillars. But it's covered with rust inhibitor ... and I'm not really a mechanical person ... so that's just what I think.
Oh. In that case, I guess any research I do will be for education only!
The 2 x 4 support system extends from above the floor in the back seat to the rear supports between the rear wheels. So the batteries sit above that.
The 2 x 4s are screwed down to the floor, the rear support has a box built around it to tie the 2 x 4s into.
Rev 2, with 4 inch square aluminum tube, should look a bit more like I designed something.
The 2 x 4's look like I made things up as I went. And I did. I started with a design that didn't work out in the first step ... so I improvised my way through it. You can likely tell that since the 'plan' I talk about at the start of the video never seems to describe what I end up with at the end. I run into issues, and I adapt.
Old 11-03-2014, 05:48 PM   #90 (permalink)
Dreamer
I have never used these controllers before so the following is just a guess.
I would say the controller giving an error when the throttle is below a few percent could be correct behaviour.
This could be the low pedal lockout to prevent start up if the accelerator cable has broken or become disconnected.
When you put the throttle control in the car the pedal would hold the throttle at something above zero with foot off.
I would imagine there would be a high pedal lockout as well which would bring up an error at 100% throttle control travel. Full throttle from the pedal (foot flat to the floor) would likely only give 95% of throttle control travel. Anything higher would be recognised as a possible return spring break and present an error.
I imagine that is why there is a calibration sequence so the controller can find where the zero pedal travel and full pedal travel appear in the available throttle control travel.
Once again this is just a guess but it makes sense to me.
The Following User Says Thank You to Astro For This Useful Post:
thingstodo (11-03-2014)
