Old 01-17-2022, 04:00 PM   #21 (permalink)
screen save
Originally Posted by Vekke View Post
Found a great wind tunnel video:
You can download official materials from here: https://media.daimler.com/marsMediaS...173#toRelation
We froze the video as near we could, sideways to the car, and made a print of it. I won't know until I get it home, if I'll be able to extract any useful information from it. Until they publish a formal technical image of the car, it will be 'way out ahead of nothing.'
Thanks for all the digging!
Old 01-17-2022, 05:25 PM   #22 (permalink)
high rez image
https://www.netcarshow.com/mercedes-...llpaper_03.htm
With the tail extension, the EQXX may become Mercedes-Benz first 'double-ended' automobile, something General Motors swore it would never touch at one time.
Old 01-17-2022, 06:08 PM   #23 (permalink)
EQXX data tidbits
1) cooling system drag= 0.007 when open
2) Frontal area is less than CLA, which for the Euro Spec CLA 180 was 2.2272 meters-square ( 23.9741 sq-ft )
3) Bridgestone tire sidewalls carefully matched to wheel covers.
4) 'slightly less than' 100-kWh
Old 01-20-2022, 01:49 PM   #24 (permalink)
EQXX photographic analysis
1) Backlighting the photograph revealed enough contrast to establish perimeter of the car.
2) Using the Length of 4630mm ( 182.28-inches )as a reference, according to the photo, the EQXX is:
3) Height = 1300mm ( 51.28-inches )
4) Body height (h) = 1180mm ( 46.45-inches )
5) Ground clearance = 120mm ( 4.72-inches )
6) aft-body = 2188.58mm ( 86.161-inches ) [ 47.27% ]
7) V = 1.85363
8) Active diffuser = 99mm ( 3.897-inches )
9) L/H = 3.56153
10) L/h = 3.92372
A) I'll try for a width from the plan-view photograph.
B) Some estimated frontal area is a target ( we can't calculate without it )
M-B has left us a few breadcrumbs to follow.
Old 01-20-2022, 01:59 PM   #25 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.85 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.42 mpg (US)
Is that after active suspension or before?
The Following User Says Thank You to alexshock For This Useful Post:
aerohead (01-20-2022)
Old 01-20-2022, 02:58 PM   #26 (permalink)
before or after
I can't answer with any clarity. I'm presuming that the EQXX is depicted in its low-drag configuration in the photograph, however, I can't vet it one way or the other.
Old 01-21-2022, 05:30 AM   #27 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
What picture did you use for your overlay?
I got 130mm ground clearance in my measurements
Car has composite springs so I think its not adjustable.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (01-24-2022)
Old 01-21-2022, 09:06 AM   #28 (permalink)
You're both within a margin of error for your display devices which could be inflated due to the method of magnification and measurement
Old 01-22-2022, 11:27 AM   #29 (permalink)
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
Considering this thing weighs about 4,000 lbs, the efficiency it gets is damn impressive. If it had half the mass and cut drag another 20%, 100 Wh/mile would be possible. Then they'd be able to strip all the luxury electronics crap and make an affordable sub $25,000 200+ mile range EV sedan that the lower middle class could comfortably afford.
Mercedes could have done something like this during the 1970s fuel crisis and used a 5-cylinder 3L turbodiesel to get 70+ mpg highway, but they kept this knowledge shelved and away from production cars all these decades. The C111-III proves it.
The Following User Says Thank You to The Toecutter For This Useful Post:
Old 01-24-2022, 11:01 AM   #30 (permalink)
pic
I used the NetCarShow.com image, at an 11-inch by 17- inch image scale.
On the light table I was able to get enough contrast to reveal the entire outline of the car.
It won't be 'true-length' though, and I don't know if they'll ever publish an actual technical drawing.
aerodynamics, eqxx, low drag coefficient
