Old 01-04-2022, 12:58 PM   #11 (permalink)
I wonder if the lower front "grill" opening provides some cooling air to components that might need it; e.g., the battery. Or, is it there for some aerodynamic purpose?
Also, I wonder if those hood vents have ducts to bring air from the lower front grill through the vents. When the smoke wand is placed to the left part of the grill, the smoke comes through the left hood vent. And when on the right, smoke emerges from the right vent. This seems to be done for aerodynamic purposes and likely keeps the front end from rising at speeds.
Old 01-06-2022, 04:08 PM   #12 (permalink)
grill
The battery is air-cooled.
Nothing is said about the power electronics or motor.
If nothing else, the grille opening would supply air to the air conditioning condenser coil.
Positioning the extractor slots where they are, taps into faster-moving, lower-pressure flow, allowing passive flow, without artificial delta- pressure power requirements.
There is a likelihood that one side is for motor cooling, and the other, AC.
And it's possible that the forebody generates zero lift / positive downforce. That was the case for my truck.
MeteorGray (01-08-2022)
Old 01-06-2022, 04:14 PM   #13 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.09 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.55 mpg (US)
>>> The result, it claims, is an astounding 95% battery-to-tires efficiency.
95% - there is literally nothing to cool
The Following User Says Thank You to alexshock For This Useful Post:
aerohead (01-06-2022)
Old 01-06-2022, 04:22 PM   #14 (permalink)
95%
That would put the combined inverter and motor at 97%, same as the Tesla 'Raven' motor in the Model Y and Model 3.
Good news!
Old 01-06-2022, 05:09 PM   #15 (permalink)
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
Especialy considering that even in highway driving this car does not require much power to sustain its speed.
The Following User Says Thank You to Autobahnschleicher For This Useful Post:
Old 01-07-2022, 04:40 AM   #16 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I think its 95% battery to motor efficiency. Drive axles and their tripods are not very efficient. I think rear drive axle efficiency is around that same 95% percentage.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (01-17-2022)
Old 01-07-2022, 01:28 PM   #17 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
The crazy part is they had a facebook ad for this car and eveybody was pissed calling it and all of the aerodynamic cars ugly. I think it looks pretty good so I was surprised. Bascially just a bunch of people saying they want boxy SUV's with their hard earned money. lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-07-2022, 02:21 PM   #18 (permalink)
Really? Isn't that what Facespook is for?
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Old 01-07-2022, 03:33 PM   #19 (permalink)
True lol
The Following User Says Thank You to hayden55 For This Useful Post:
freebeard (01-07-2022)
Old 01-17-2022, 03:23 PM   #20 (permalink)
air suspension
Originally Posted by Vekke View Post
Premier was out the Cd number is 0,17
My takes from the video compared to EQS which should be 0,20:
- Air exit scoops on the bonnet
- Closed wheels so no venting for brake cooling
- Bigger air curtains and taller in heigth
- wheelwell exit vents on rear edge in front and back tires. Nicely designed specially the front ones look neat
- Rear diffuser lowers and extends about 120mm rough estimate
- Mirror legs even thinner ones like they use in their sports or race cars.
Car propably has air suspension which lowers the car a lot, but it was not mentioned
According to Edmunds, in 2010, M-B had what they call an 'Airmatic' suspension system, claimed to reduce drag by 3%.
aerodynamics, eqxx, low drag coefficient
