Old 02-01-2010, 01:32 PM   #31 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
A 1/2-tonneau like bow is doing on his truck,along with a cab-wing extension can get you close to the mpg of an aeroshell,and stil maintain the "open" bed.
I don't know about lowering the rear end.That could cause separation over the roof and would compromise any mods behind the cab.
The truck has a natural rake to it, so that the bed actually slopes downward to the cab. I assume by lowering the rear, he's attempting to level the truck out some, so that the bed doesn't act like a forward facing scoop.
Old 02-01-2010, 02:30 PM   #32 (permalink)
raked vs level
My thought is that the standard rake affects all the fore-body flow,forcing it always into a positive pressure regime as the truck advances.
Lowering the tail takes some of the "wedge" out of the profile and could threaten the energy at the very back of the roof,something automakers have worked very hard to get since the late 1980s.
This could compromise the viability of any bed mods.
Conventional aerodynamic wisdom is to raise the tail as much as practical to achieve the reflex-camber worked out with the banana car.
Trunklid heights have come up on cars and bed rails and tail gates for the same reason on pickups.
If the whole truck could be lowered it might be a better solution.Should a load of "full-capacity" ever be added to the bed,you sure wouldn't want the tail to sag.Very dangerous to stability.
Only testing would reveal a "scoop" effect.The majority of pickups have a locked vortex contained within the bed,often with air flowing backwards over the tailgate into the bed.
Adding a soft tonneau allows the air to strike the back half causing an indentation in the fabric,while the low pressure of the vortex attempts to lift and suck away the forward half.
GM's patented 1/2-tonneau exposes the front face of the tailgate to the low pressure of the vortex and with it,the relative delta-p across the gate for net thrust and a little better mpg.
Christ (02-01-2010)
Old 02-01-2010, 02:45 PM   #33 (permalink)
And, there you have it.
Old 02-01-2010, 04:34 PM   #34 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
Alot of Dak/Dur owners remove the stock clutch fan and run only the electric fan for the AC without any issue. (Fuel Hungry 5.9L R/Ts too!). I'm guessing the Gen IV Dakota's still have an E Fan for the A/C.
- Greg
Old 02-01-2010, 05:51 PM   #35 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
They do.
I will look into the wing ( I already have a cover ) and lowering.
Old 02-01-2010, 06:45 PM   #36 (permalink)
Got any ideas for a Q/D wing? You could probably rob one from a Caravan Sport, if you've got access to a JY. Might have to glue in some plastic sheet to smooth it out, but it might mount right to the cab without too many problems.
Old 02-01-2010, 07:00 PM   #37 (permalink)
What are "Q/D and JY?"
Old 02-01-2010, 07:02 PM   #38 (permalink)
Quick and Dirty
JunkYard.
Old 02-01-2010, 08:07 PM   #39 (permalink)
How long does the wing need to be? Do you have a picture of what it should be?
Old 02-01-2010, 08:18 PM   #40 (permalink)
Quick and Dirty
JunkYard.
Thanks for that.
Miata modding bobsiopener Aerodynamics 22 10-02-2013 06:32 AM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 10:47 AM
High Flow Muffler on a 2006 Dakota dwhitney89 General Efficiency Discussion 9 04-30-2011 12:11 PM
What's the worst that could happen?? and other modding ?s I have swoody EcoModding Central 25 09-17-2008 07:23 AM
New user intro and pick-up aero modding Blackbird Aerodynamics 4 01-28-2008 12:06 PM
