Old 11-27-2017, 12:03 AM   #11 (permalink)
EPA highway rating is 22 HWY. You ought to be able to at least be getting close to that without doing anything. Unless your driving 85 MPH everywhere, there's something wrong.
https://www.fueleconomy.gov/feg/bymo...Windstar.shtml
Old 11-27-2017, 05:10 AM   #12 (permalink)
Originally Posted by Tinchariot View Post
I think I might add a flapper valve on the cold air intake , so the engine warms up faster, then open cold air on the Hwy for a free turbo effect or when it's ready. Maybe something like what was used on carbureted cars air cleaners.
You mean something similar to a choke, or to the flapper valve which was used in Brazilian dedicated-ethanol cars?
Old 11-27-2017, 01:57 PM   #13 (permalink)
Tinchariot's Avatar
My fuel useage results are only bases on 350 miles of driving & not over 65 mph. I did a relative compression test and all cylinder are equal. All 02 senors were changed , MAF, T-body & IAC were cleaned. Found a leaky fuel injector & system pressure is below spec's. With new injectors I will update the results.
The hot/cold intake mod might use parts from a carb air cleaner.
Old 11-27-2017, 02:04 PM   #14 (permalink)
Tinchariot's Avatar
One good thing this 1995 windstar is OBD2, just bought a scangauge to monitor the fuel usage.
Old 11-27-2017, 02:48 PM   #15 (permalink)
Tinchariot — Point of order.
The OP of this thread is Wonderjava (Last Activity: 09-26-2014 06:35 PM). Even though it's a zombie thread and the OP hasn't posted in three years, it would be more seemly to start a new thread.
You could ask the mods to spin your contribution off into another thread. I'll leave how you do that as an exercise.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Tinchariot (11-27-2017)
Other mods (Will this list of aero mods get me 5% more MPG?) spydyr Aerodynamics 11 01-17-2012 09:55 AM
"Top 10" list of mods for beginners - do we need one? What would you pick? MetroMPG EcoModding Central 28 06-05-2010 04:38 PM
could we estimate the gains expected from mods modmonster EcoModding Central 9 01-15-2010 09:32 PM
Cd change for irreversible mods Piwoslaw Aerodynamics 3 11-14-2009 05:50 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
