Old 06-23-2014, 02:21 PM   #11 (permalink)
darcane's Avatar
Originally Posted by Axsle View Post
If the clicking is caused by rotation, then wont they cut the valve stems?
No, the clips will flex in and out, the cap don't rotate in relation to the wheel. Pull them off after a while and you will see scratches that go straight in and out.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 06-23-2014, 02:25 PM   #12 (permalink)
darcane's Avatar
Well that's annoying. I originally bought them so I wouldn't have to deal with broken zipties on my last wheel covers. This is more annoying.
I like the idea of the hubcaps aerohead uses but they sound hard to find
Mine haven't fallen off after 16k miles and climbing.
The Dzus-fastener moon caps can be purchased from Moon Eyes. The fastening brackets need to be welded on though, so few people other than racers use them.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Axsle (06-23-2014)
Old 06-23-2014, 03:11 PM   #13 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Has anyone here ever tested out "mud plugs"? I found them a while ago and like the idea but not sure how well they work in practice. I'm wondering mostly about balance being affected by the adjustment mechanism. But I guess if you have them balance the wheel and tire with the ring in place, it should all balance out properly.
AERO Gen. II 15 Inch Wheel Non-Beadlock Mudcover Kit - Speedway Motors, America's Oldest Speed Shop
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 06-23-2014, 11:46 PM   #14 (permalink)
I haven't tried them, but you could put the clamp opposite the valve stem to balance against it.
I remember the expanding ring part, but not that it uses 4 Dzus fastners. You could clamp the ring in place and run a bead of adhesive around it.
