Old 12-14-2010, 09:40 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
More efficient air intake (1.6HDi) - ideas
My car's intake is a little messed up. The route that air must go before it gets to the manifold is very long and full of kinks and bends. The air filter is buried deep behind the engine, so by the time intake air hits the turbo it's had more than enough time to warm up - good if you have a gasser and want a WAI, but bad if you have a turbo diesel which prefers cold air.
Here is a diagram of the pre-turbo part:
and picture of how it's all crammed in there:
Fresh air gets scooped up by the intake (1) and goes into a "box" (2) which in many official documents is called an air filter. It has no filter inside, in fact it's not even an air tight box - only one wall (with in and out ducts) and a cover. My guess is that once inside, air must slow down and make a U-turn inside, and that removes debris and water. But when the car is not moving and no air is being forced through the intake (1), then a large protion of the air sucked from box (2) actually comes from inside the engine bay. Next the air goes around the battery to the real air filter (3) way back behind the engine, from which it comes back forward to the turbine (6). From there it passes through the intercooler (7), pressure sensor (8) and finally hits the intake manifold.
So why is the filter behind the engine, while the same car with the larger 2.0 liter turbodiesel has the filter box up front? My guess is that having to take apart half the engine bay just to change the filter will send more customers to the authorized service station... ($$$)
Well, I don't want my air box snuggled back there between the engine block and the EGR pipe, soaking up the heat. Putting an air filter box up front would allow air to take a much shorter and direct route to the turbo, reducing both pumping losses and air temperature. But any new ductwork would have to account for the air flow and temperature sensor (nr 4 on the photo), and maybe for a mysterious pipe connecting the air duct with the header cover (nr 5 in the photo), the purpose of which I have no idea.
Any ideas on what to change? Is redoing the whole intake ducting worth the results?
ID:	7522   Click image for larger version
Old 12-14-2010, 02:36 PM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
to answer your question is it worth it. I would say yes.
read the following articles
Part 1
Browser Warning
Part 2(important one on intakes)
Browser Warning
Part 3(maybe not so important for ecomodding)
Browser Warning
Part 4
Browser Warning
Part 5 (The results section has important info)
Browser Warning
dyno with just intake and exhaust mods
http://autospeed.com/cms/gallery/art...0&a=109345&i=7
Would it be possible to fit the 2.0 liter intake system to your engine?
The Following 2 Users Say Thank You to ConnClark For This Useful Post:
ecomodded (07-09-2014), Piwoslaw (12-14-2010)
Old 12-14-2010, 04:27 PM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
ConnClark, you linked to part 1 twice. The link to part 2 is:
Our Peugeot Diesel - Part 2 - The Intake
I'll have to see. I'd be willing to install anything that will fit and improve flow, but staying with the same make and/or model may reduce the need to improvise weird-shaped parts. I'd like to find a mechanic who has more experience than I do (which means pretty much anyone) and maybe he could suggest something. I'm also waiting for my local Peugeot forum to go back online so I can ask about that mysterious header cover connection.
Old 12-15-2010, 08:50 AM   #4 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Could you not draw air directly above the current filter position- maybe from an area similar to the heater vents?
Old 12-15-2010, 10:28 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
My cabin air vents are located at the bottom corners of the windshield (bottom of A-pillars) and the pressure there seems to be quite low - I get no air inside if I turn the fan off, no matter how fast or slow I'm going - so I'd lose the ram effect. This would negate any gains from reducing the number of bends ahead of the filter box in the present set-up.
(Are the pictures from the first post gone? Can anyone else see them?)
(EDIT: Got it fixed.)
Old 12-16-2010, 03:18 PM   #6 (permalink)
DieselMiser
ConnClark's Avatar
I never could see the pictures in the first post
Old 12-16-2010, 04:09 PM   #7 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Doesn't look to me like changing your intake will result in any measurable change. Just because it has turns doesn't mean there is any measurable resistance at your airflow rate...maybe you could gain 1 hp on the top end with an aftermarket intake, but then you'd inhale more dirt.
If you ditch it, let us know if you get any efficiency gains.
I'm not coasting, I'm shifting slowly.
Old 12-17-2010, 01:57 AM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
The bends are half of my worries. The other is the length of the ducting and it wraps around the engine, warming the air much more than I'd like. Getting rid of all that plastic would also free up some extra room, say for a larger battery, or some other gizmos.
And no worries about aftermarket race filters - I'm not interesed in filters that look like a fishing net - I want to keep the dust and water out.
Old 12-17-2010, 05:35 PM   #9 (permalink)
Have you thought of wrapping the intake in the "thermal reflective" tape?
Old 12-22-2010, 09:35 PM   #10 (permalink)
That is one of the weirdest setups I have seen are there any rubber air pipes if so change then to hard pipes. Plastic and rubber flexes and can cause boost leaks or spikes. a more direct air intake to the turbo and from the turbo to the intercooler and from the intercooler to the engine is a good idea. I'm not sure the hard pipes to the intercooler would work well check ebay for a universal kit that you could cut up and rought yourself this will help greatly. Hard pipes can increase hp as they do not flex. If the intercooler will not accept the piping where it is (it looks like it is on top of the motor. Try and relocate it either to the side or the front of the vehicle this will help lower your air temps. For filters I'd suggest a AEM dry flow which has been used in desert or off road racing so no dust or water will get in.
2 cars one never gets driven the other is an MPG project already at 5% increase in standard driving economy CAI and Pulstar plus. Thinking weight reduction next year.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
WAI vs Ram Air Intake --- at speed... basslover911 EcoModding Central 33 07-17-2009 06:34 PM
Considering a Warm air intake stevey_frac EcoModding Central 0 07-01-2009 03:32 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
