Old 03-04-2009, 04:30 PM   #11 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
i have an idea now...if i ever stumble upon some sheet metal...
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 03-04-2009, 08:44 PM   #12 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.06 mpg (US)
Hinge it at the trailing edge of the roof. Lift it up, then open the trunk.
Designed properly, it would help straightline speed and fuel economy. Not sure about stability though (rear lift).
Old 03-05-2009, 07:57 AM   #13 (permalink)
MPG...what?
exactly what i'm thinking...only the hinge part...how can i make it look good
-10 Yaris sedan
-96 Tercel
Old 03-05-2009, 12:39 PM   #14 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
The complete opposite happened to my car. We got a half inch of icy snow overnight. The afternoon sun warmed it up just enough that it slid off the hood and piled up on the front bumper like a beach blanket. Wish I could've watched it as it was sliding!
-Terry
Old 03-07-2009, 12:13 AM   #15 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Probably the easiest way to get a nice-looking, smooth hinge is to just let the middle section bend. If you have a fiberglass or lexan piece with a gentle bend across the top and the edges bent down, you can bond the whole front edge to the roof, and then cut two t-shaped slots in from the edges near the top. When you lift at the back, the center section, between the tops of the "T"s will buckle to flat and make a fine hinge, and still snap back to give good beam stiffness when down.
Old 03-07-2009, 12:51 AM   #16 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
malibuguy -
Assuming for the moment that you find a match, you *could* mount a roof spoiler and build the hinge off that :
This would give you a "foundation" for quick mount/dismount of the kamm-back. The mounting holes would be in the spoiler (no leaky into roofy).
CarloSW2
American Solar Energy Society
Old 03-07-2009, 08:19 AM   #17 (permalink)
MPG...what?
hmmmm...only thing is they make nothing for the trailing roof edge of these cars...i dunno, i'll stumble across something somehow
-10 Yaris sedan
-96 Tercel
Subaru Outback Kammback Experiment brucey Aerodynamics 18 11-16-2014 02:45 AM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Accordion Kammback for big rigs ? Cd Aerodynamics 36 02-27-2012 05:03 AM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 12:23 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 06:07 PM
