03-03-2015, 08:21 PM
#21 (permalink)
Just cruisin’ along
By the math, should be a 3% difference. But EVERY hack on every forum always claims a 10% diff...
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
04-11-2015, 08:53 PM
#22 (permalink)
Originally Posted by litesong
All 3 cars show mpg increases for E0 of 8%, 7% & 5%...... 87 octane E10 has ethanol molecules that average 114 octane.... ALSO, the gasoline molecules must average 84 octane, IF an average octane of 87 is to be created, while blending 10% ethanol.
This is simple: gasoline engine engineers designed 87 octane gasoline engines to run best with 87 octane 100% E0. Ethanol engine engineers designed 114 octane ethanol engines to run best with 114 octane 100% ethanol. Ethanol/gasoline blends run neither gasoline or ethanol engines best.
Since I only claim 8% to 5% E0/E10 mpg differences, am I LESS of a hack?
Good ethanol engine engineers designed high 114 octane, high compression ratio(16:1) ethanol engines to get the most energy AND work out of 100% ethanol. Ethanol, as used(but NOT burned efficiently) in low 87 octane, low compression ratio (9:1 to 12:1) gasoline engines, cannot give up energy & its work, nearly as efficiently. That is why adding only 10% ethanol to gasoline, lowers mpg 8% to 5%.
Already stated, is that 87 octane E0 is 87 octane(& is NOT BASE octane 84 mixed with high octane premium to average 87 octane). But 87 octane E10 is a mis-brewed mix of 114 octane ethanol AND 84 octane gasoline molecules, neither of which perform optimally in 87 octane gasoline engines designed to burn 87 octane gasoline at its best.
04-11-2015, 10:34 PM
#23 (permalink)
10% ethanol fuel has been a fact of life here for around a decade or more. I tried E0 in my 2011 Fiesta and at 80 cents more a gallon and 60 miles out of the way the mileage needed to increase by a little over 25% at that time when it was pushing $4 a gallon versus $3.20 for regular E10.
In sealed systems I have seen E10 go over a year without issues and my Honda pressure washer started fine after sitting for close to 6 months all with no additives.
E10 is one of the reasons we are importing much less than the 50+% of the crude oil we were importing before the mandates. I am neither and ardent advocate or opponent, and I understand the principles involved in choosing that renewable option, over crude from unpredictable sources.
Most EFI cars have no problem with E10, my 23 year old Sentra runs fine on E10, in fact the cheapest E10 I can find, without a hiccup, but EFI systems are much better equipped to handle the lower energy content than carbs and non feedback systems.
04-12-2015, 07:44 AM
#24 (permalink)
Needs More Duct Tape
It's great to have fuel choice for old cars, trucks, lawn tractors and yard tools.
I'm on my second tank of 87 octane E0. Not sure if I'll go for a third.
Slambo saw a jump on the first tank from 39.7 to 42.8, but that may be partially due to the warmer temps.
Slambo! - #AintFuelin (Honda Civic) | Fuelly
E0 is not available in NJ. I have to drive nearly three hours round trip to Allentown, PA to fill up. It's $1 per gallon more than the least expensive top tier 87 octane E10 is locally.
04-12-2015, 03:00 PM
#25 (permalink)
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab 90 day: 20.98 mpg (US)
The only reason E10 is cheaper than E0 is subsidization. So we pay less for gas, more for food, and our tax dollars go to enrich corn farmers instead of other activities where they might do more good.
As for importing oil - we don't need to do that anymore. Whether or not we should is another question. But it can no longer be said that adding ethanol to gasoline is reducing our dependency on foreign oil; technically we have no such dependency.
04-13-2015, 06:12 PM
#26 (permalink)
like many stated, to many variables between different cars and engines to give an accurate MPG loss with e10. it will effect some more than others.
now, e85, will drop MPG compared to e10 or e0 in any car. but, if your car is tuned for it, and the fuel system can handle it, you can have major performance increases. A buddy has a turbo charged Cobalt and runs E85, makes over 400 WHP with it. if he tuned on straight gas hed be making a lot less.
that being said, Im not a fan of ethanol at all mostly because i ride a 2 stroke sled and its hell on them things. even my carbed 4 stroke quad, I have to drain all the gas from the carb before putting it away for the winter or it will just make a mess in there.
04-16-2015, 01:10 PM
#28 (permalink)
Is there an MPG difference?
It depends on the vehicle.
The 4.6L gas murdering town car we had could not tell the difference between E10 and E0.
The 1.8l turbo in the bug gets worse MPG on regular, I only have E0 RUG here. Comparing E10 mid grade or premium gas and E0 RUG is not a valid comparison.
The Hyundai always gets better MPG on the E0 gas than the E10.
05-01-2015, 01:32 PM
#29 (permalink)
The EPA & "ethanol in gasoline industry" forced & suppressed E0 to rarity. E0 is impossible to get in most big cities. Also, penalties can be imposed if oil companies go short on 100% ethanol-free gasoline to blend with ethanol. Lately, EPA may be light on this last requirement. Anyhow, E0 rarity drives up E0 price.
05-01-2015, 01:54 PM
#30 (permalink)
I ended my E0 testing after two tanks. The MPG gain was near expected (in the 3% range). The financial/time cost (+$1 per gallon/3 hour round trip to fill up) did not justify continuing the test. I will revisit it at a later date.
E0 is fabulous for old lawn mowers, weed wackers, motorboats, and classic cars. But it offers no cost advantage for modern vehicles (that have been designed to run on E10).
