Old 11-27-2018, 03:20 PM   #1 (permalink)
royanddoreen's Avatar
z - '03 nissan 350z touring
90 day: 36.21 mpg (US)
Diniro - '18 Kia Niro Ex
90 day: 47.99 mpg (US)
Mpg drop in winter.
I guess I would be right in saying that a hybrid loses more mpg due to cold weather than a car with ice only. Living in this cold climate I’m probably not getting as big a gain from my last car ice as I hoped I would. Never factored this variable in when I bought my Niro which was getting 4.5l/100k now i’m Getting 6l/100k which is still decent I know.
Old 11-27-2018, 04:40 PM   #2 (permalink)
I drive an all electric leaf and I am seeing around a 20% drop in range and economy.
Old 11-27-2018, 04:49 PM   #3 (permalink)
I think the mpg drop is very similar in hybrids and gasoline only vehicles. Hybrid's gas mileage is just so much higher that the numerical value drop makes it seem like its larger.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Frank Lee (03-21-2019), redpoint5 (11-27-2018)
Old 11-30-2018, 12:23 PM   #4 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I saw about a 20% decrease this morning when I turned on the heater in the Volt
Old 11-30-2018, 02:50 PM   #5 (permalink)
2015 WRX - '15 Subaru WRX
90 day: 30.63 mpg (US)
2008 Suzuki SV650SA - '08 Suzuki SV650SA
90 day: 60.81 mpg (US)
Not sure how cold it is where you are, but that's pretty typical. There are a lot of factors that reduce economy in cold weather:
- cold engine
- cold transmission and differentials
- higher air density increasing aero drag
- higher air density increasing engine pumping losses.
- spinning on slick surfaces, or slow traffic on slick surfaces
A block heater helps quite a lot for shorter trips. Grill blocks will help a bit too.
Old 11-30-2018, 05:48 PM   #6 (permalink)
Cold weather, ICE vs. HEV
HEV may take a bigger percentage hit due to:
1) the inherent loss of efficiency the ICE experiences in cold weather
2) HVAC heating demand forces ICE to run when it otherwise wouldn't
3) when hybrid batteries are cold (NiMH < 50°F), the battery utilization is seriously throttled thus reducing the hybrid efficiency, primarily in regenerative braking.
The Following User Says Thank You to S Keith For This Useful Post:
redpoint5 (11-30-2018)
Old 11-30-2018, 06:46 PM   #7 (permalink)
I don't have NiMH or internal combustion engine in my car and see a pretty dramatic drop in range and economy.
Old 11-30-2018, 06:48 PM   #8 (permalink)
Which is completely irrelevant because the OP is asking about HYBRIDS.
Thanks for chiming in though.
Old 11-30-2018, 06:54 PM   #9 (permalink)
I'm just saying the economy loss we see isn't all due to the internal combustion engine or battery being cold.
For me it takes more power to maintain speed when cold.
So cold tires, cold transaxle oil and increased air density would be shared between gas, hybrid and pure electric.
Old 11-30-2018, 08:30 PM   #10 (permalink)
Bill the Engineer's Avatar
Hybrids lose mileage in cold weather because the IC engine has to run more often to keep the emission control components warm enough to work properly. There are LOTS of postings over at priuschat.com about this.
Bill the Engineer
