Old 08-05-2013, 06:51 AM   #31 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Originally Posted by Vaders View Post
Hello Meelis, I've been researching the MPGuino for the past few days and I've found some basic parameters for my car. Again, I'm new to this, what exactly will need to be done for the install? How difficult is it to install? How do I program these parameters into the device for accurate readings? Anything else I should know?
Thank you!
I can answer too..
First you need to find the speedometer signal and injector signal(only from one injector) see the MPGuino wiki.
Then you need to input your basic parameters(speed and injector signal pulses), then drive around like this says: Mpguino calibration - EcoModder
The difficulty... Well you need a multimeter and common sense
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 08-12-2013, 09:06 PM   #32 (permalink)
Cool! Thanks!
Originally Posted by Quezacotl View Post
I can answer too..
