Alright, so I couldn't find the information any where else.. I have a 1989 CRX HF and I can't figure out what injector to tap into and where the vss line is located.... Any help would be much appreciated.
Thanks
Check out my project here---> 1989 CRX HF
does your ecu have 2 or 3 plugs? honda OBD0 pins should be standard across the board. is it possible the previous owner did a swap on the harness and ecu?
if your B10 is yellow/blue or orange color wire, then that's the one for your VSS
while you're at it, you can also check the ECU number and see which one your CRX is running to verify that it's a OBD1 Honda ECU List - HondaSwap Forums
if you're engine isn't original, check the engine model stamped on the block. here's a list of honda motors to triple check your OBD1 Honda Engine List - HondaSwap Forums
