Old 07-23-2012, 07:44 PM   #1 (permalink)
wyatta4's Avatar
CRX:HF - '89 Honda CRX HF
90 day: 53.05 mpg (US)
NameGoesHere - '15 Volkswagen Golf TDI SEL
MPGuino in CRX
Alright, so I couldn't find the information any where else.. I have a 1989 CRX HF and I can't figure out what injector to tap into and where the vss line is located.... Any help would be much appreciated.
Thanks
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
Old 07-23-2012, 08:23 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
This might be helpful : crxMPG – Gas mileage never looked so good » SuperMID: Fuel Economy Display
Old 07-24-2012, 12:40 AM   #3 (permalink)
wyatta4's Avatar
No I've read that before. It doesn't tell me what wires to get in to.
Old 07-24-2012, 03:56 AM   #4 (permalink)
tuned2save - '93 Honda Civic VX
90 day: 41.56 mpg (US)
this might help. OBD0 pinout diagram on honda-tech.
looks like B16
Obd0 Pin out - Honda-Tech
Old 07-24-2012, 12:12 PM   #5 (permalink)
wyatta4's Avatar
My B pinpoints are different than that... I have that photo..
Old 07-25-2012, 04:58 PM   #6 (permalink)
does your ecu have 2 or 3 plugs? honda OBD0 pins should be standard across the board. is it possible the previous owner did a swap on the harness and ecu?
pics will help
Old 07-25-2012, 07:21 PM   #7 (permalink)
wyatta4's Avatar
3 plugs. Previous owner didn't have an ECU and he said that he didn't swap anything..
I'll post photos tonight..
Old 07-25-2012, 09:11 PM   #8 (permalink)
if it's 3 plugs, it's a OBD1 ECU/harness. check the OBD1 diagram here
ECU Pinouts, VTEC wiring, & ECU VTEC Conversion Information - HondaCivicForum.com
if your B10 is yellow/blue or orange color wire, then that's the one for your VSS
while you're at it, you can also check the ECU number and see which one your CRX is running to verify that it's a OBD1
Honda ECU List - HondaSwap Forums
if you're engine isn't original, check the engine model stamped on the block. here's a list of honda motors to triple check your OBD1
Honda Engine List - HondaSwap Forums
Old 07-25-2012, 11:26 PM   #9 (permalink)
wyatta4's Avatar
Mine looks like that obd0 one. Not the obd1
Old 07-27-2012, 03:16 PM   #10 (permalink)
wyatta4's Avatar
Here's my ECU and wires..
Quick photos.. sorry for the lack of detail.
