Old 02-19-2013, 11:44 AM   #31 (permalink)
wyatta4's Avatar
CRX:HF - '89 Honda CRX HF
90 day: 53.05 mpg (US)
NameGoesHere - '15 Volkswagen Golf TDI SEL
Originally Posted by razor02097 View Post
I had the same issue happen once. The speed signal would jump around like crazy. I think the guino got confused with a key off somehow.
Yeah I can't key off or it happens... So I guess I'll have to make a kill switch.
So do you think that is my problem Meelis? Just keying off messed it up for a bit?
If that's the case thn it doesn't make sense to me how it didn't get fixed after skis connecting it from the power and resetting everything...
Check out my project here---> 1989 CRX HF
Follow me on Twitter. @secsieAzul
Old 02-19-2013, 12:13 PM   #32 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
If you key off the reed switch in our older cars no longer produces a signal. The ECU shuts down... maybe the combination of the 2 things cause the MPGuino to go nuts. I found if I shut down the engine with the key and wait 1 or 2 seconds before keying on again the MPGuino behaves.
When mine messed up it was some time before the MPGuino started working correctly again.... but it did start to work on it's own again.
Project Avalon: E bike build
