Old 10-28-2013, 12:40 PM   #71 (permalink)
The OPs truck has a Getrag which is where my advise was directed. The only things I know for certain about the NV5600 is that it was only used by Dodge for a few years and it is a very expensive transmission to repair. My advise is purely cautionary and is drawn from the experiences of other Cummins owners on other boards. If you hurt or destroy any manual trans in a cummins powered truck, it will very quickly eat up the value of any fuel savings you had realized.
Travis..
Old 10-30-2013, 02:27 PM   #72 (permalink)
90 day: 19.36 mpg (US)
The later six speeds (and 5-speed NV-4500) remain an option for nearly any CTD. I've nearly 200k on the original clutch on my 5600. And have driven 1T DRW oilfield hotshot (upwards of 30k gross, combined) where the trans does just fine (some install clutches with greater holding power) given the hardship. The near million-milers pulling heavy loads aren't and weren't breaking these transmissions.
"Breaking" a manual transmission is usually a matter of being a fool behind the wheel trying to hurry the shifts. Same mindset that adds a "tuner" where it is hardly justified (if ever) for the loads being moved.
Be sure to filter out those with commercial experience and those whose trucks are little more than toys.
A well-built automatic trans, OTH, will set you back $4k and more.
Old 10-30-2013, 08:26 PM   #73 (permalink)
I think we are pretty much on the same page. Yes lots of guys breaking stuff are doing so by abusing them. BUT, lots of people have had issues with their G360 in normal use from the time they were new. I don't hotrod or abuse my truck (91 W250 diesel, G360), but you won't find me lugging it and letting the trans and transfer case rattle like a box of rocks either. I don't think engine off coasting or extreme low rpm for the gear are good for the trans and wanted the OP to know that if it breaks it will be an expensive fix.
Travis..
Old 11-03-2013, 12:39 PM   #74 (permalink)
Yes, we are. It is for those who come along later (not knowing much at all abou these trucks, but are considering their use) that some tech points ought to be aired. Other manual transmissions than OEM are a possibiiity, and pluses/minuses weighed. As well as "what constitutes lugging". I'd imagine that I can -- with a Third Gen CTD -- come closer to that what with much more sophisticated engine controls. We none of us would recommend the last bit of FE if it compromises reliability/longevity, but some trucks WILL be more capable than others over a broader range.
Old 02-26-2019, 08:32 AM   #75 (permalink)
So what happened to this truck?
Old 02-26-2019, 08:46 AM   #76 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
I sold it after an icy winter and getting stuck without 4x4. I won't own another rwd truck as long as I live in Michigan.
I own a fleet of diesel box trucks now that I've done some light aero modding on, but haven't done much in the way of hypermiling the last few years being as busy as we are. My wife and I own/operate a major appliance retail/ repair company.
The Following User Says Thank You to mikeyjd For This Useful Post:
slowmover (03-01-2019)
Old 04-27-2020, 04:53 AM   #77 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
yeah the two-wheel drives are a little special when it gets icy ,it's like a one-legged man trying to go ice skating. it makes lots of noise it gets attention but it just sits there.
Too slow movers point. The nv4500 5th gear nut backs off due to the harmonic resonance torque twisting the shaft. And yes 5th gear @25mph is lugged
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 04-27-2020, 01:17 PM   #78 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by Big Dave View Post
This project has a lot of merit. My truck is fairly similar.
Quick question: Stick or automatic? Just on the face of it a stick is good for a 2 MPG gain. An automatic pretty much forecloses engine-off operation unless you can repair automatics economically..
you can always get an electrical Aux transmission pump.. it was invented
good luck finding one GM owns the rights to it
https://patents.google.com/patent/US20100050626A1/en
Old 05-11-2020, 05:13 AM   #79 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Wouldn't an electric power steering pump do the job?
Former
87' Hyundai Excel
