Old 02-19-2017, 03:43 AM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
My new ride!
Prior to the purchase, I had never sat in a Miata (let alone driven one) and I saw this one pop up on Craigslist 10 miles from me, so I went to take a look, as soon as I took it for a test drive, that was it, I immediately fell in love with it. I have driven a few S2000's (including a nice supercharged one) but the Miata felt more 'fun'. I ended up buying it, even though it has a few deficiencies, for 3500$.
The pros:
Paint looks pretty good.
Timing belt/water pump/thermostat done within 15k miles.
Clutch done within 15k miles.
Catalytic converter replaced 5k miles ago.
Alternator/battery replaced ~a year ago.
New soft top with glass rear window. (unknown replace date, sometime in the last 20k miles/2 years).
New radiator (~20k miles ago).
LSD (at least, I believe it's LSD, it lights up both tires on the dirt so...).
129k miles.
Brakes at 90%.
Cold A/C, Nice and warm heater.
Now for the cons...
Leaks in the trunk when it rains, this is due to the rubber seal missing in one spot.
Grinds if I rip-shift into 3rd from 2nd.
Lowered and has the roughest ride I have ever felt in my entire life.
Driver side seat needs replaced (all tore up).
Steering wheel falling apart.
Leaks oil like hell from valve cover gasket (and I believe the CAS as well).
Badly worn front tires from the lower, inner tread was showing steel belt.
Rear tires mismatched.
No cruise control.
Now for why I bought it with the above deficiencies for 3500... I have been buying used cars for dirt cheap, just to wind up spending a lot of irritating hours and countless money on trying to fix all the problems. This car had the two major things done to it, timing belt and clutch and had paperwork to prove all the work I claimed above.
I already addressed the suspension issue, I found all 4 stock shocks/springs for 50$ on Craigslist and bought them, swapped it over and now it rides awesome.
Now for some pictures! Please note the top two were taken before I swapped the suspension and removed the side skirts.
The Following User Says Thank You to Baltothewolf For This Useful Post:
RedDevil (02-23-2017)
Old 02-19-2017, 03:48 AM   #2 (permalink)
Furry Furfag
Here is some stuff I plan on doing. In no particular order. Most of it is silly fantasy stuff I'll probably never end up really doing, some of it is more pressing.
Mechanical things to do.
Replace front tires. (Done, got 4 Dz102's)
Replace shocks.
Fix oil leak.
Stop belt squeal.
Replace transmission fluid.
Change spark plugs.
Sway bar bushings.
Sway bar links.
Tie rod ends.
Things to do for interior.
Clean interior. (Done).
Dash carpet.
Add Cruise control.
Drivers seat. (Replace/repair)
Steering wheel. (Replace)
Climate control faceplate. (Replace)
Shifter boot. (Replace)
Emergency brake cable cover. (Replace)
Door panels. (Replace)
Speakers. (Replace)
Lube window channels.
Screws/bolts for steering colum.
Trunk lid seal(replace).
Remove roll bar.
Add interior lighting.
Exterior.
Wash and wax paint. (Washed, but not waxed yet).
Remove trunk cargo rack, repaint and add rubber protection for paint.
Fix door locks on both doors.
Replace windshield wipers.
Repaint rims.
Repaint window trim.
Repaint front bumper lip.
Old 02-19-2017, 03:49 AM   #3 (permalink)
Furry Furfag
Uhg I meant to put 'My new ride' but I'm a little out of it. If a mod sees this, can they change the thread title to 'My new ride! ('95 Miata).
Old 02-19-2017, 05:29 AM   #4 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Nice clean ride you have there. Enjoy!
Old 02-19-2017, 07:47 AM   #5 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Looks like a fun car. Enjoy it.
Old 02-19-2017, 08:32 AM   #6 (permalink)
90 day: 39.99 mpg (US)
Subscribed. Looks like it already has a nice air dam and, at least from the pictures, the paint looks good.
Old 02-19-2017, 12:13 PM   #7 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
so clean :3 here in finland miatas have expensive hype tax
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 02-20-2017, 08:50 AM   #8 (permalink)
No problem, fixed it for you.
Looks like a nice clean car! Congrats. It looks like fun.
Old 02-20-2017, 09:20 AM   #9 (permalink)
Furry Furfag
It's a respray, but it actually looks pretty decent. No overspray on the rubbers all around, and no overspray on underpanels or under hood stuff.
Thanks everyone for the encouragement. I'll be changing the tie rod ends when I get home from work, and taking her to get an alignment.
Old 02-20-2017, 10:19 AM   #10 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Can you see anything with that mask on?
