Old 12-04-2012, 07:00 PM   #1 (permalink)
Rusty Marina's Avatar
Need input on buying a pickup
I'm looking to buy a pickup, nothing new just something inexpensive I can occasionally use. I need one to pull a car trailer and some of my junkers I have, but gas is just too expensive these days. 15 years ago I wouldn't care if it were a one ton with a 454 or 460 engine.
I've narrowed the choices down to a few :
80-90s Fords with the reliable 300, decent mpg potential but the 5 speed Mazda I'm told is junk.
88-90 something Chevy f/s with a 4.3 V6 , seems a 5 speed with that combo would be a good pick.
Or even a 6.2 or 6.5 diesel, not powerful but 22 mpg potential with the ability to pull a mild load.
I'd consider the Ford 6.9 and 7.3s as they are good engines, but they are 3/4 ton trucks and I don't know how bad the fuel economy would be on top of diesel already costing .60 to .80 more per gallon. Not sure if they can handle 22 mpg like the 6.2 GM diesel although they are probably a better engine overall.
Any input on any of these ?
Old 12-04-2012, 07:08 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
A ford straight 6 300 would be a good choice to stay with gas motors, there very torqy motors as well as being reliable as it is a straight motor which tend to last longer.
I would not go with any big block gas motor, if you go with a 1 ton vehicle a diesel would be the way to go as your economy would be higher.
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
Rusty Marina (12-05-2012)
Old 12-05-2012, 01:47 PM   #3 (permalink)
I've seen a couple 460 Fords that were in decent condition and drivers for $800-1000 but I know my wallet cannot support one at the pump.
A 300 will pull a car and a trailer with no issues, and I like the fact 300s seldom have issues.
Thanks !
Old 12-05-2012, 02:18 PM   #4 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Any of the midsized pickups with a V6 like toyota, or Nissan might do you too, though they tend to sell for more used.
Old 12-05-2012, 02:28 PM   #5 (permalink)
The Dirty330 Modder
Gealii's Avatar
but if he plans on pulling a car he would need to upgrade the suspension. my bros f150 302(brand new upgraded suspension) was just about bottomed out pulling a 96 Taurus on a trailer. and the frame is not as strong which will also be taking quite a bit of abuse
- Henry Ford
Old 12-05-2012, 02:45 PM   #6 (permalink)
TheEnemy's Avatar
The frames themselves are quite strong, I would suggest a load leveling reciever hitch, if you load the trailer properly 500lbs tounge for class III even the lighter trucks without a load leveler will not nose up all that much.
Old 12-05-2012, 02:57 PM   #7 (permalink)
TheEnemy's Avatar
Here is a very similar thread, slightly different requirements such as passengers, but slowmover was very informative for me.
http://ecomodder.com/forum/showthrea...cle-23966.html
Old 12-05-2012, 05:51 PM   #8 (permalink)
I'd be happy if I could find a decent condition 6.2 GM diesel or 6.9 Ford 3/4 ton but most older diesels always appear to have the wheels driven off them, maybe I should consider spending more.
Old 12-05-2012, 06:01 PM   #9 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
If it was bottomed out someone wasn't balancing the car on the trailer correctly. IIRC you should have about 100 lbs on the hitch- then all you have to worry about is fishtailing.
Old 12-05-2012, 07:53 PM   #10 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
diesel truck on SearchTempest
- Tony
