07-12-2018, 08:06 AM
New Aerodynamic Truck Bed Cover.
Just learned of this one. Nice styling job. Be interesting to put this one in a wind tunnel. Bondo
https://www.mivehiclesolutions.com/a...conversion-kit
Reason: (added image for posterity)
The Following 5 Users Say Thank You to bondo For This Useful Post:
07-12-2018, 09:13 AM
I like that, kind 1970's looking with the louvers.
fROM THE ORIGINAL OPENING LINK:
Not to detract from the tread, but could some of the manufactures be doing small things to help the aero on their trucks?
As found on AUTOWEEK
Spied: 2019 Ford Ranger Wildtrak roams with Ranger Raptor
http://autoweek.com/article/spy-phot...-ranger-raptor
07-12-2018, 01:46 PM
Good find, Bondo.
I'll check it out.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
07-13-2018, 09:57 AM
Someone in the Pelican Parts forum where I posted it just compared it to the Pontiac Aztec.............................ruined it for me.
I still like it, just was an unexpected comparison.
Post #41159
http://forums.pelicanparts.com/off-t...ures-2058.html
07-13-2018, 01:59 PM
I like their solution for rear visibility; using the louvers in place of glazing. So, it is (probably) not water tight, but it is less costly.
Edit: I see it has a glass window under the louvers - which seems clunky, now.
07-13-2018, 03:13 PM
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
No claimed mpg savings figures?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
The Following 2 Users Say Thank You to LeanBurn For This Useful Post:
07-14-2018, 08:03 PM
Originally Posted by kach22i
I think they were going for a Mustang fastback but I saw the Asstec in it as well.
07-18-2018, 10:52 AM
cover
If they did a product placement in a Transformers,Mission Impossible,X-Men, James Bond,etc. motion picture;they'd probably fly off the shelves.
07-18-2018, 12:44 PM
#9 (permalink)
The angle is too steep, would not fit the Aero-Template.
That said, I bet it's an improvement verses nothing at all.
07-19-2018, 02:23 PM
#10 (permalink)
If the louvers were v-shaped instead of straight then they may act like a step hull of a boat, reducing wetted area intern drag.
Making channels for the higher pressure on the sides to merge with the lower pressure center while minimizing disturbance of the front to back flow.
Im curious if the severe reduction in Reynolds number would mute any effect from this design in the air, or if the speed at which it works is too high for Road use.
from https://www.boatingmag.com/stepped-h...hull-0#page-20
Step hulls reduce the amount of running surface in contact with the water by ushering a cushion of aerated water under the hull via one or more transverse indents known as steps (A).
The aerated water also exerts upward pressure (B) on running surfaces (C) to lift the hull, maintain a consistent trim angle and boost efficiency when the boat is on plane. All other things being equal, this can result in higher speeds — some estimates run 10 to 15 percent higher — versus a conventional V-hull.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
