10-14-2010, 06:49 PM
#31 (permalink)
Hey nice timing on your post. I am about to set my own record and go 400 miles on my Ranger. I know I should be happly about not going to the gas station, but until I get that receipt and crunch the numbers, the MPG is unofficial. It is driving me a little crazy waiting to hit Empty. You must have been dieing waiting 7 weeks for the trip to the gas station!
10-14-2010, 09:39 PM
#32 (permalink)
Souldn't the electricity used to charge the battery be included in the mileage calculation?
regards
Mech
10-15-2010, 09:08 AM
#33 (permalink)
Hypermiler
I did list the electricity used, for completeness, but it's hardly significant.
Use the X-prize conversion of 34 kwh = 1 gallon
0.74 kwh / 34 = 0.02 gallons
13.75 + 0.02 = 13.77 gallons
1133 mi / 13.77 gallons = 82.28 mpg, down from 82.4 mpg.
That's a difference of 0.12 mpg.
07-30-2019, 02:29 AM
#34 (permalink)
Cyborg ECU
Originally Posted by PaleMelanesian
I just beat my distance record! Thanks to an excessively hot summer, among other things. It took 7 weeks of commuting, 10 miles at a time. I started with the tank topped off until gas was sitting in the filler. I ran it down until it sputtered and died. A gas can (2.000 gal) in the back got me to the station for the rest of the fill.
1133 miles
13.751 gallons
82.4 mpg
Mods:
Grille block - smooth upper, 3/4 lower to leave a little airflow
Tire pressure - high
Mobil1 5w20 oil
Scangauge
Battery trickle charger. Too much EOC runs the battery down. 0.74 kwh for the tank.
A highly adjusted nut behind the wheel.
Techniques:
P&G EOC
conserving momentum
light timing
route selection
low speeds
low rpm shifting
parking at the uphill end of the lot, facing downhill for a rolling start (I enter at the top, so I just stop there)
NO AC
Blast from the past! And this legend, hypermiled car (retired) deserves both the sticker picture and the hat picture from the 70 MPG Challenge club.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
07-30-2019, 10:05 AM
#35 (permalink)
Hypermiler
Thanks! My new car, commute, and life are not up to those standards these days. I'm happy with mostly 50+ tanks now.
Despite the similar ratings, the Fit is not as efficient as the old Civic, by at least 10%. And my route is shorter so more of the time is spent in warmup mode. And it's not as aerodynamic. But the hatchback is so much more useful I made a deliberate choice on that point.
My best tank in the new car is 72 mpg.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
07-30-2019, 04:03 PM
#36 (permalink)
Cyborg ECU
Yup. I see it in your fuel log, too: Aug. 18, 2014... so the PaleFit also qualifies for the hat picture and the sticker picture.
11-19-2019, 05:04 PM
#37 (permalink)
Diesel Doer!
That's really impressive considering your run time is so short. I was able to get 78 mpg out of my VW Lupo 1.9l non-turbo by just driving it normally, using all the hypermiling tricks. My 2014 US Passat got 1,000 miles from its first tank and about 850miles driving it at 75-80 all day...
