Old 11-20-2014, 12:06 AM   #11 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Originally Posted by Lovemy92vx View Post
Michelle in Denver here. I also bought a 92 VX. Found it on eBay, flew to NC and drove it back. It has 267000 miles on it and has gotten as high as 47 mpg 2/3 city highway, 1/3 city. It has also dropped to a mere 39 the past two fill ups.
My mechanic is thinking thermostat or distributor since it also would not re-start at a drive through. Obviously I avoid idling.
The engine is being gently cleaned and I'm changing the oil every 2,000 miles.
It had a recent tune up, has new tires set for current weather conditions.
I've been using regular gas (10% ethanol), from the same Shell station.
Until the past cold snap, the weather was mild with little wind.
Anything you can suggest to be more consistent? What might explain this?
I Also have a 97 HX and have some widely (-5, 6) varying mpgs
Start out by removing the variables, check the tire pressure to make sure you're not low on pressure.
The very first thing I do on a high mileage Honda is a timing belt water pump tensioner and pulley.
You said tune up but the first task with an undocumented car is to assume nothing has been done. I would order an oem Honda tune up kit on eBay with cap rotor wires and plugs and fuel filter. The car dying is an indication of a spark or fuel problem.
Your driving style also needs to adapt to lean burn, on my hx its 5th gear from 52mph to 78mph. It should feel like the car takes a lot of throttle to stay at highway speed
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following User Says Thank You to Chrysler kid For This Useful Post:
leety (11-24-2014)
Old 11-20-2014, 12:19 AM   #12 (permalink)
90 day: 30.54 mpg (US)
Originally Posted by elhigh View Post
That post was not too long.
So far I don't think I've seen a post that I considered "too long" unless it was someone selling 100% Unicorn Oil.
Or Free Energy. Oy.
Do you not even look at my posts?!
Old 11-23-2014, 06:48 PM   #13 (permalink)
Pearl - '92 Honda Civic VX
Thank you! I should start my own thread?
* I apologize newbie girl if i stepped on you. I am just excited to find advice and folks w shared interests. I am a complete novice at this!*
To your kind response. Replaced broken thermostat, (assume new oem Honda parts unless otherwise recommended), tune up, cleaning dirty engine (oil 2000 miles w BGs MOA, it looks rusty but my guy says it's oil build up.
Timing belt package before new fuel jnjectors? He said I had about a year on the t-belt, but if I will see a bigger mpg. I will do that next. Any suggestion on injectors?
The distributor may only need an ignitor?
The Following User Says Thank You to Lovemy92vx For This Useful Post:
leety (11-24-2014)
Old 11-23-2014, 09:11 PM   #14 (permalink)
Re: point to car dying. It actually just didnt re-start as i shut off the engine at a drive up window. Three cranks (i counted 1,2,3...pause) over 30-45 seconds and she came right back to life w no issues since.
Old 11-23-2014, 10:31 PM   #15 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
I would second the advice about the tune-up and also suggest a fuel filter. I also usually dig right into brakes on any car I pick up on day one.
welcome aboard ladies and good luck!
thanks,
Victor
Old 11-23-2014, 11:24 PM   #16 (permalink)
Thanks for the kind welcome!
Full tune up w Honda parts already done. Afterward i had two half tank fill ups yield 47 mpg. I will ask about the fuel filter. Maybe air filter too.
(new tires and brake pads already :-)
Old 11-23-2014, 11:28 PM   #17 (permalink)
Team "Old SKOOL"
Did you put air in the tires after they were installed as well? Most of us here run Max recommended pressure on the sidewall or higher
Thanks,
Victor
Old 11-24-2014, 03:02 AM   #18 (permalink)
This thread is pointless without pictures.
http://ecomodder.com/forum/showthrea...tml#post444578
Old 11-24-2014, 11:18 AM   #19 (permalink)
Yes, thanks. Do you recommend differently for winter? I am in Denver with cold, snow and altitude.
Old 11-27-2014, 03:48 PM   #20 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
In my experience over the last 7 years, colder temperatures and winter gasoline (they start selling it in November around northern Arizona) contribute to about a 7% reduction in fuel economy compared to warm weather and summer gasoline. It's quite noticeable in my car's fuel log graph.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
