Old 01-27-2014, 12:34 AM   #11 (permalink)
Civic Type-DX - '97 Honda Civic DX
90 day: 40.3 mpg (US)
Cool. I'm really interested in TDI's, I like the interiors a bit more than my Honda's. Nice pickup for 400!
Old 01-27-2014, 02:06 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Darin - Yeah... yeah I do. lol
I get bored. That's a problem I have lol
At least I'm still working on the Festiva D swap though... just takes time.
Old 01-27-2014, 06:25 PM   #13 (permalink)
American Viking's Avatar
Dad's Jetta - '05 Volkswagen Jetta 2.5l package one
90 day: 23.23 mpg (US)
Black Cherry - '01 Honda VFR800fi
Last 3: 39.39 mpg (US)
Originally Posted by Christ View Post
I didn't really want to fix the VR6. I needed something better on fuel than my van, and really prefer diesel engines in general. The VR6 did sound pretty badass, though, so I may use the GLX wagon I'm getting to fix the Jetta and take the brake parts for the Pasta from that one. Well see.
I prefer the Diesel as well, but around here Diesels are coveted.
ex. My 2005.5 Jetta 2.5l with no know issues was less than $5600, whereas a 2006 TDI base with 197,000 (more than twice the mileage of my 05.5) plus a boatload of issues was listed for $7900 (and it needed probably another 2500 to pass inspection).
In the end I'm thrilled with the 05.5.
Old 01-27-2014, 06:32 PM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Welcome back. I sometimes wondered what had happened to you. Glad you have returned! Subscribed.
Christ (01-28-2014)
Old 01-28-2014, 01:23 PM   #15 (permalink)
I come and go, man. I'm a drifter.
As far as how many cars I go through... you guys don't even know the half of it. Other than the ones that have been detailed on this forum, I've had an additional 15 or so in the last 7ish years. No big deal to me, cars are like underwear... they get a little uncomfortable after you've used them so long. :P
Old 02-01-2014, 09:15 PM   #16 (permalink)
I got my silicone vacuum lines in the other day, and I've had the headlight I needed to replace for some time now, but since it got fairly warm out today [37F], I decided to get off my duff and work on the car some.
It's had a fairly obvious oil spray under the hood for awhile now, to the tune of about a quart lost every 2-3 days, which has literally turned EVERYTHING under the hood a very shiny shade of black lately. At first I assumed it was coming from the dipstick, since it seemed to accumulate most there, but I was wrong. Anyway, dipstick tends to tell you that you have either excessive blowby, not enough ventilation [plugged PCV/CCV], or in the case of the TDi, a very bad vacuum leak.
Figured I'd check the CCV filter first, since it's easy to get to. As I'm removing the lower block vent pipe from the filter on top of the engine, I notice LOTS of excessive movement... take a quick look down there and realize that... umm.. the flange is broken in about 18 places. FOUND THE OIL... LEAK.
Apparently the VR6 engine uses the same part [maybe] so I'm gonna check that out tomorrow [Sunday, my birthday] and if not, I'll be ordering a $23 piece of friggin' plastic.
In addition, I changed the headlight and got the front looking... less broken.
But now [dun dun dunnnnnnn] the battery light's been on for about 2 days. Started out intermittent, now it's on steady, but here's the kicker - the battery hasn't died yet, including several cold starts in that time. The lights are significantly more dim while the alt light is on, but the alt is clearly still charging to some extent.
Anyway, the VR's alternator is 130A, which is an upgrade to the existing one, and it's not like I have any other use for it than a spare, so I'll toss it on and rebuild my existing one as a spare in the mean time. While I'm in there, I'll more than likely remove the AC components, too, for some weight savings and less belt drag, since I'll never use it.
Next up, complete vac line swap... all 35 feet of them.
Old 02-02-2014, 05:29 PM   #17 (permalink)
There used to be a hose running between the two red circles. Fixed the oil spray issue using stock block plate and a cap from a can of 'Start ya *******' (actual brand name, not actually the brand I used) and a stock hose clamp. Later, Ill be plumbing a crankcase evac system and catch can.
No progress on vac lines as yet, nor brakes/suspension upgrades.
The Following User Says Thank You to Christ For This Useful Post:
California98Civic (02-02-2014)
Old 02-02-2014, 11:45 PM   #18 (permalink)
I wish I could get a Passat TDI for 400 bucks back here...
Anyway, that's still a nice ride, a good base for many eco mods.
Old 02-03-2014, 09:14 PM   #19 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Have you tried washing them?
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 02-04-2014, 02:06 AM   #20 (permalink)
Nope. Woman does that.
