Old 09-22-2012, 03:16 PM   #1 (permalink)
retrodynamic
retrodynamic's Avatar
Lightbulb Novel Rotary-Turbo-InFlow Tech / Gearturbine Project – Featured Development
*GEARTURBINE PROJECT:
Atypical InFlow Thermodynamic
Technology Proposal Submission
Innovative [TURBO-ROTARY]
Novel (Fueled) Motor Engine Type
-The Gearturbine comes from the contemporary ecological essential global needs of an efficient power plant fueled motor engine. -Power thrust by bar (tube); air, sea, land and power generation, work use application.
*Have the similar simple basic system of the "Aelopilie" Heron´s Steam Turbine device from Alexandria, [10-70 AD] one thousand nine hundred years ago. Because; the circular dynamic motion, with 2/Two Opposites power [polar position] lever, and is feeds from his axis center.
YouTube Video/10.30 min; * Atypical New • GEARTURBINE / Retrodynamic = DextroRPM=> VS <=LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
-Desirable Contemporary Innovation, With the Possible [Efficient] Invention. -Mechanical [Thermodynamic] Universal Human History Evolution. [Unlike] Epic Technology Revelation. -Next Step Power-plant New Design Form Function Device Change.
*8-X/Y Thermodynamic CYCLE - Way Steps:
1)1-Compression / bigger
2)2-Turbo 1 cold
3)2-Turbo 2 cold
4)2-Combustion - circular motion flames / opposites
5)2-Thrust - single turbo & planetary gears / ying yang
6)2-Turbo 2 hot
7)2-Turbo 1 hot
8)1-Turbine / bigger
*Innovation Technology Break Barrier / Paradigm [Broken-Seal] Solution. State of the art. Innovative Turbo-Rotary concept Top system.
-With Retrodynamic Dextrogiro vs. Levogiro Phenomenon Effect. / Rotor-RPM VS InFlow / front=> to <=front; "Collision-Interaction Type" - inflow vs. blades-gear-move. Technical unique dynamic innovative motion mode. [Retrodynamic Reaction = When the inflow have more velocity the rotor have more RPM Acceleration, with high (XY Position) Momentum] Which the internal flow (and rotor) duplicate its speed, when activated being in a rotor (and inflow) with [inverse] opposite Turns. A very strong Novel concept of torque power thrust. At field explanatory example with a metaphor is like if a sailboat take the wind from his prow front to move; wind/inflow + knots/rpm + wind/inflow + knots/rpm + wind/inflow + knots/rpm + etc... = Acceleration x Acceleration = Exponential Acceleration. Whereas it has more movements forwards, it receives a frontal impulse still but to move more forwards. A present example of the implementation of the Retrodynamic effect is in the application in the accelerator (and collider) of particles that this in the border of Switzerland and France.
-Shape-Mass + Rotary-Motion = Inertia-Dynamic / Form-Function Wide [Flat] Cylindrical shape + positive dynamic rotary mass = continue Inertia kinetic positive tendency motion / all the complete Rotary motor mass weight is going with the power thrust move circular direction.
-Non-waste parasitic looses system for cooling, lubrication & combustion; -Lubrication & Combustion, inside a conduit radial position, out way direction, activated by Centrifugal Force-Fueled Injected. -Cooling; a) IN-Thermomix flow, & b) OUT-Air Thermo transference.
-Combustion 2Two [Inside-Rotary-Dynamic] continue circular [Rockets] flames. Like two dragons trying to bite the tail of the [ying yang] opposite other.-Increase the first compression by going of flow reduction of one big circumference blades going pass to 2TWO reduced, very long distance (total captive compression) INFLOW [inside propulsion] CONDUITS [long flow interaction] [like a digestive system] Start were ends, in perfect shape balance in perfect equilibrium well balanced, like a snake bite his own tale. -4 TURBOS Rotary [inside-rotary-active] [In-Flow, Out-Flow] Total Thrust-Power Regeneration [Complete] Power System. -Mechanical direct 2two [Small] "Planetary Gears" at polar position. Like the Ying Yang Symbol/Concept. Wide out the Rotor circumference were have much more lever [HIGH Torque] POWER THRUST. -Military benefits, No blade erosion by sand & very low heat target profile.-3 stages of inflow turbo compression before combustion; 1)1-Turbine, 2)2-Turbos 3)2-Turbos. -And 3 points of power thrust; 1-flow way, 2-gear, 3-turbine.
*The most innovative power plant motor engine project today. Higher efficient % percent. Next trend wave toward global technological coming change.
Patent; Dic. 1991 IMPI Mexico #197187 - Carlos Barrera. - Individual Designer - Inventor and project owner. / All Rights Reserved. - Monterrey NL Mexico.
Featured Project Development State of the Art Novel InFlow Tech 1Gearturbine Reaction Turbine RotaryTurbo Similar System of the Aeolipile Heron Steam Device from 10 70 AD With Retrodynamic DextroGiroRPM VS LevoGiroInFlow Ying Yang Power Type 2Imploturbocompressor Impulse Turbine ImploDucted One Moving Part System Excellence Design InFlow Goes from MacroFlow to MicroFlow by ImplosionAnd Inverse One Compression
Old 09-22-2012, 10:53 PM   #2 (permalink)
If its not more than about 40% efficient then its not worth it.
Looks too complicated to be very efficient.
What are the thermodynamic process at work here?
Old 09-23-2012, 03:20 AM   #3 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Sorry, butt this reeks of the rainbow smear depicted below....way too much pseudo speak goin on there to be credible, makes entabulators seem quaint by comparison. Biggest brown flag waving is the 1991 patent....21 years you'd think they'd have a working prototype on the road with a few hundred thousand miles of research results by now.
Just did a web search, there is nothing solid made by this crack pot, if this doesn't fit the definition of Unicorn, then nothing does.
In fact, this isn't even worth laughing at it's so pathetic.
Old 09-23-2012, 07:51 PM   #4 (permalink)
retrodynamic
ChazInMT; the pseudo speak its just a simple technical information, and all the document text material have backup, and Im ready to make the working prototype from time ago, but I still have secrets to hide.
oil pan 4; 40% ok, What are the thermodynamic process at work here? you dont see?
The point of breake are gone a come from India.
Old 09-23-2012, 11:01 PM   #5 (permalink)
Aero Deshi
ChazInMT's Avatar
Sorry man, I've run into guys like you before. You are so spellbound by your own babble crap you don't even have a remote grasp on reality. People in this forum are far from idiots and will see this for what it is. It isn't even worth my time to try and discuss any of it with you. This is my absolute last response on this thread topic.
Best of luck to you.
Old 09-24-2012, 05:49 PM   #6 (permalink)
retrodynamic
Thumbs up
Sorry man but, no way jose, What you are talking about. You are talking alone at a mirror.
I dont post this project information at this great forum, to talk about me, talk about my concept.
All the information I show have back up.
You can check the patent number, its a document.
But you are swing the bat at an empty air. Why not just put the finger were its hurts, and tell me the technicals negative points at my project. what you can find is a efficient system, from simple form-function. you see.
Old 09-24-2012, 06:01 PM   #7 (permalink)
retrodynamic
Thumbs up similar simple basic system of the "Aelopilie" Heron´s Steam Turbine device
ChazInMT; if this (Epic-History) Technical Information, its not interesting for you, I realy cant imagine, and dont know what can be interesting for you:
For example.
Last edited by retrodynamic; 09-24-2012 at 06:08 PM.. Reason: just to put emoticons
Old 09-24-2012, 06:13 PM   #8 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Gas turbine - Wikipedia, the free encyclopedia
Already in use, up to 60% efficiency
Old 09-24-2012, 09:56 PM   #9 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 40.78 mpg (US)
I tracked down the "patent". It is not a patent, it is a dead patent application. A patent was applied for in Mexico in 1999 by Carlos Alberto Barrera Garza. The application dragged on until 2004. The abstract is full of the same "imploturbocompressor of dynamic flows" technobabble of the OP's original post.
There is no such thing as secrets to hide when applying for a patent. International patent law requires that all patents be written so that any person "skilled in the art" can build the thing that is being patented.
Technobabble is specifically not allowed. Every single word in the patent must be both technically and legally correct.
Anybody can apply for a patent, but the patent office decides if the patent will be granted.
And if the patent had issued, it would have expired last year. Everything in it is then public property and can be freely used by anybody for any purpose whatsoever.
The Following User Says Thank You to JRMichler For This Useful Post:
Ryland (09-26-2012)
Old 09-25-2012, 12:45 AM   #10 (permalink)
Thermodynamic process are universial, india, russia, mexico the USA, it doesn't matter.
Garbage like "Compression / bigger" or "Combustion" are not thermodynamic processes.
engineering, innovation, mechanical, motor, technology
