Old 09-02-2009, 09:10 AM   #21 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
Originally Posted by tom43571 View Post
electromike,
I will go ahead and order it then, possibly two in case I screw something up. My only other worry is the interface for the chip. It looks much more difficult to build than the one for iso and with my extremely limited electronics knowledge, it should prove to be a serious challenge.
ELM provides schematic, PCB design and even the gerber files for their interface, you could use them to help you build the interface
ELM Electronics - Chip Help
take a look at the "Where can I buy a circuit board for my ELM IC" paragraph
2013 Hyundai Sonata Hybrid
Old 05-17-2010, 05:08 PM   #22 (permalink)
herman
well,
I finally bought the duino. now, i need to build everything.
so, i was reading the tutorial code.google.com/p/opengauge/wiki/OBDuinoDiagram and there is nothing about my car's protocol.
my car is a 2000 year Ford with SAE J1850 PWM protocol. on that tutorial i saw ISO and CAN protocols.
I have an ELM327 interface working on my computer, but, how i need to plug the led display on the freeduino?
i bought this nkcelectronics.com/freeduino-serial-v20-board-kit-arduino-diecimila-compatib20.html and this nkcelectronics.com/16x2-lcd-module-while-characters-blue-backli162.html
thanks a lot by the help....
Old 05-17-2010, 09:04 PM   #23 (permalink)
OBDuino coder
Magister's Avatar
Your ELM327 interface is a closed enclosure? if it's the case you have to put a "NULL modem", a cable with TX/RX crossed, between your ELM interface and the freeduino. For the LCD there is a diagram on the wiki of the project
OBDuinoDiagram - opengauge - Whole diagram of the Arduino board, LCD, interface - Project Hosting on Google Code
Old 05-18-2010, 08:43 AM   #24 (permalink)
herman
i assembled my elm327.
i dont understand yet. here code.google.com/p/opengauge/wiki/OBDuinoInterface there is the interface with elm327 but the PWM protocol dont is used.
the pins 3, 4, 11 e 13 of the elm327 chip are not used on the diagram above. i must to buy the MC33290 chip too? the PWM will be converted on CAN protocol?
i am lost
but, again, thanks a lot by you help.
Old 05-18-2010, 08:56 AM   #25 (permalink)
OBDuino coder
Magister's Avatar
I assumed you have a full ELM327 interface, bought from eBay for instance? If this is the case then everything is inside to support all the protocol.
If not you have to built around your protocol with the various components needed, transistors, etc
A quick google find this:
http://images.forum-auto.com/mesimag...ns%20titre.jpg
Old 05-18-2010, 09:38 AM   #26 (permalink)
herman
yeap. I bought the ELM327 chip and assembled to all protocols. and it is working ok, but only on my computer. I think that is just plug the serial port of the ELM scan to serial port of the arduino. i think that is ok.
my problem is to put the LCD display on the arduino. how i need to connect the wires? which ports? on which pins? i need to buy the MC33290 chip? i just use this image opengauge.org/%7Eobduino/diagram/obduino.gif?
Old 05-18-2010, 09:43 AM   #27 (permalink)
OBDuino coder
Magister's Avatar
Yup I think it's the right diagram.
In the code it says :
#define DIPin 4 // register select RS
#define DB4Pin 7
#define DB5Pin 8
#define DB6Pin 12
#define DB7Pin 13
#define ContrastPin 6
#define EnablePin 5
#define BrightnessPin 9
it seems ok to me
Old 05-18-2010, 04:32 PM   #28 (permalink)
herman
i found what i wanted.
Arduino - LiquidCrystal
let me talk what i think about connect the arduino with my car and you can say if there is right or not.
I have the elm327 working. I will to assemble my arduino kit with LCD 8x2 like the schematic on the link above. After this, I will write a program in C/C++ to connect the arduino's serial port to elm327 serial port and read rpm, speed and so on.
Its right or I am entire crazy now? hhahahhaha....
thanks for you patience
Old 05-18-2010, 04:43 PM   #29 (permalink)
OBDuino coder
Magister's Avatar
This is what the OBDuino is doing, just connect your LCD as the diagram, and load the sketch in the Arduino IDE, compile, upload
obduino32K.pde - opengauge - Project Hosting on Google Code
uncomment the define ELM and comment the define ISO before compiling.
Also I don't remember if you need a crossed cable between the serial port of the Arduino and the ELM327 interface or a straight one!
Old 05-19-2010, 12:49 PM   #30 (permalink)
herman
hum......ok.....the code seams to be all that I need....great heheh..
i will assemble the lcd and arduino on this weekend. maybe i need some help ahead.
thanks a lot.
obd2
Working with Carbon Fiber larrydag Aerodynamics 17 10-25-2014 03:21 PM
Tips for working with plastic, Coroplast, polycarbonate orange4boy Aerodynamics 0 08-30-2008 04:15 PM
Glossary Not Working? Skroober Forum News & Feedback 3 06-28-2008 12:29 PM
SGII backlight not working? ch00f Instrumentation 3 06-18-2008 03:22 AM
