Old 09-15-2008, 03:00 PM   #1 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
Smile OBDuino working with ELM327 (pix + movie)
Yesterday I made my first real test with the OBDuino connected to my car, and it worked
Here is a picture at idle, note that the display is in L/h because speed is 0.
I also made a small movie, but in my code I had a problem with a value being signed so sometimes the fuel display goes negative (I corrected it in the trunk code).
Unfortunatly it seems google resized the movie to 320x240 and I was taking it with my digital camera while driving so quality is not very good, but at least it shows you the thing. I display fuel consumption, speed, RPM, load.
2013 Hyundai Sonata Hybrid
Old 09-15-2008, 03:05 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Nice! I love the low quality background music.
Old 09-15-2008, 03:16 PM   #3 (permalink)
OBDuino coder
Magister's Avatar
Thanks, and sorry for the music, this was the radio but the volume was low, I didn't know we would hear it, I should remove it from the video
Old 09-15-2008, 11:32 PM   #4 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Yay keep it up!
Old 09-16-2008, 07:30 AM   #5 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
I would make one of these with a larger display, to be able to look at six or eight gauges at a time. That would be sweet. I think you guys are onto something here. Good luck and keep us posted.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 09-17-2008, 01:14 PM   #6 (permalink)
OBDuino coder
Magister's Avatar
I added menu configuration, you can now configure LCD contrast and if you want metric unit or imperial.
I also added "virtual" screens, there is 3 screens, each displaying 4 infos, you rotate through them by pressing a button. It makes 12 infos available quickly. I will add them in the configuration too.
Buttons act like this:
Code:
        realtime display      menu display
LEFT    rotate screen         decrease, select NO
MIDDLE  go into menu          apply and go to next item
RIGHT   rotate brightness     increase, select YES
BTW here is my ELM interface:
Old 09-19-2008, 10:44 PM   #7 (permalink)
OBDuino coder
Magister's Avatar
random pictures:
The Following User Says Thank You to Magister For This Useful Post:
lamb.chop (01-19-2012)
Old 09-21-2008, 12:20 PM   #8 (permalink)
Hi,
Check tihis post i did, your wish is on the way
http://ecomodder.com/forum/62481-post217.html
Old 04-22-2009, 11:00 PM   #9 (permalink)
herman
hello guys....
i'm looking for a display to show how much gasoline my car is using...
i built the elm 327 scanner last week and i think that this will work perfectly....
so, where i can get the projects to build a display like this?
thanks.
marcelo.
Old 04-23-2009, 09:05 AM   #10 (permalink)
OBDuino coder
Magister's Avatar
If you have a serial ELM327 interface, I think you just have to plug it to the serial plug of an Arduino clone. I don't know if you need a straight cable or a cross one however!
If you have a USB version you will have to wire pin 16 of the ELM327 to pin 1 (TX) of the Arduino and pin 17 of the ELM327 to pin 0 (RX) of the Arduino.
Project is described here
OBDuino - opengauge - OBDuino Description - Google Code
obd2
Working with Carbon Fiber larrydag Aerodynamics 17 10-25-2014 03:21 PM
Tips for working with plastic, Coroplast, polycarbonate orange4boy Aerodynamics 0 08-30-2008 04:15 PM
Glossary Not Working? Skroober Forum News & Feedback 3 06-28-2008 12:29 PM
SGII backlight not working? ch00f Instrumentation 3 06-18-2008 03:22 AM
