Old 10-24-2022, 01:57 PM   #11 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Why use petrol or diesel tho? For me it only makes sense to do this if you can do it with something that is both cheap and unusable as motor fuel in it's original state.
Old 10-25-2022, 03:53 AM   #12 (permalink)
That's a good point.
Old 10-25-2022, 06:47 AM   #13 (permalink)
Most of the info about it is in Portuguese, and still not so much on the internet. But I remember the "reactor" was reported missing in 2011 when the police depot where the Corcel and the Mercedes-Benz truck had been stored for a long time was finally reopened in order to clear it.
Hmmm... that woke the 'conspiracy theorist' in me...
I had another look and found:
https://www.econology.info/Chambrin-...ection-engine/
It's a direct translation that makes little sense.
But scientifically sound, mature, in use industrial processes happen at a
"...temperature range of 100–600 °C, the ratio of C2H5OH to H2O in the range of 1:3–1:6..."
https://link.springer.com/article/10...44-021-01945-6
That's 75% to 91% of your fuel is water...
Here one can see the difference between a liquid fuel burning and the same fuel burning when heated to a gas:
https://youtu.be/FQ81XLRFuFw?t=884
My point being that even if there is little to no Steam Reformation happening in an onboard system;
you are still adding waste energy (value) to your fuel
and
Any un-reacted steam will do what steam does for economy, which is generally good things.
The challenge is getting enough air into the engine when the fuel, as a gas, takes up so much volume.
Some sort of direct gas into cylinder injection system will be required and I doubt current systems will work with, or can be modded to work with, a gas.
pgfpro (10-25-2022)
Old 10-25-2022, 07:31 AM   #14 (permalink)
I just posted a link to a blow torch warming up where one can see the difference between a fuel burning as a liquid and as a gas.
The same trick was used on old tractors that started on petrol, then changed over to paraffin once warmed up.
NB: that these engines had a very low compression ratio, so the octane rating of the fuel was of no consequence...
In today's engines one would have to use Diesel ignition.
ie:
Spray in the fuel at the right time to auto ignite, rather than a spark at the right time.
My point being that:
No; you don't have to use petrol or diesel in the steam reformation process.
Any old oil/s etc should work to some useful degree.
Search:
plastic to fuel pyrolysis
But it does seem that methanol works best at the temperatures attainable from waste exhaust heat.
pgfpro (10-28-2022)
Old 11-02-2022, 02:04 AM   #15 (permalink)
There are many conspiracy theories about Jean Pierre Chambrin roaming around. Some say the reactors which "disappeared" in Porto Alegre went to different places, one remaining in Rio Grande do Sul (I just don't remember if Alegrete or Bagé) while the other was reportedly in Arizona or Utah.
Maybe looking at the system fitted to some CNG-capable engines such as the Volkswagen TGI range for inspiration, even though the higher temperature required to turn a liquid fuel to the vapour phase may be an issue.
