04-20-2012, 12:00 PM
#61 (permalink)
Can you post up an excel file with the calculations? I would love to play around with comparing different vehicles and weights. I know I can just use the online one, but then i've got like 5 windows open and have to copy and paste the data to my excel file to side by side compare more easily.
Thanks.
04-20-2012, 12:28 PM
#62 (permalink)
Excel on aero resistance and power
Dear Steffen707,
I have the spreadsheet but cannot open it myself. I īdonīt have the proper program.
I think I saved it with Open Office and then I erased the program.
Give me yr email and I will send it to you anyway.
OldBeaver
Mercedes 300 D turbo 1993
04-20-2012, 01:41 PM
#63 (permalink)
email sent in pm
04-23-2012, 02:10 PM
#64 (permalink)
Post 57 links to another forum with a spreadsheet available for download. I'm not sure if it's the same one oldbeaver used:
http://ecomodder.com/forum/showthrea...tml#post184492
04-23-2012, 06:04 PM
#65 (permalink)
Tools for drag resistance and such...
Dear MetroMPG,
I used the tools provided by ecomodder here:
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Enter to FORUM, then look for GARAGE & TOOLS
Choose TOOLS and there you are...
Luck !
OldBeaver
04-23-2012, 11:59 PM
#66 (permalink)
Originally Posted by MetroMPG
The spreadsheet discussed on post 51 isn't the same as the one on the tools section. It is a whole lot more complex, which isn't BAD, but i was hoping to get the simple version found on the tools section.
05-22-2012, 06:52 PM
#67 (permalink)
thank you!
08-20-2012, 11:47 AM
#68 (permalink)
Bu - '08 Chevrolet Malibu LS 90 day: 32.29 mpg (US)
Fe vs road speed is an inverted bathtub. This spreadsheet is only useful within a small speed range (around 80kph).
11-17-2012, 02:16 PM
#69 (permalink)
Hello, Ive been a long time lurker here on this board - a search usually finds the information I'm interested in, so I haven't ever really needed to post.
I am trying to derive a simple (read: very simple - no Crr, Δm, a, etc.) mathematical model for the rate of fuel consumption with regards to air resistance only, assuming constant V and m.
So far I've gotten:
B=(BSFC/ρη)Fd
Where η, efficiency, Fd, drag force, and ρ, energy density, are known.
η=1/(BSFC*ρ) => BSFC=1/(η*ρ)
B=fuel consumption (which I'm ultimately trying to find in gal/100mi).
I figure this would be the correct thread. Am I on the right track? If not, any insight would be great.
Thanks, and nice to finally meet everyone!
11-17-2012, 04:50 PM
#70 (permalink)
fuel consumption
So far I've gotten:
B=(BSFC/ρη)Fd
If you have a baseline mpg at a steady 55-mph,or 70-mph,and have made changes which affect only the drag coefficient,then the following relationships developed by General Motors, may be used with a high degree of confidence:
*A 10% drag reduction @ 55-mph will yield a 5% increase in mpg .
*A 10% drag reduction @ 70-mph will yield a 6% increase.
From here.you can convert into any useful unit of measure.
The relationship presumes a constant BSFC,and it has been reported by others that proper gear-matching is necessary to derive the full benefit of the drag reduction,but thermodynamically,the percentages are correct.
