Old 04-20-2012, 12:00 PM   #61 (permalink)
Can you post up an excel file with the calculations? I would love to play around with comparing different vehicles and weights. I know I can just use the online one, but then i've got like 5 windows open and have to copy and paste the data to my excel file to side by side compare more easily.
Thanks.
Old 04-20-2012, 12:28 PM   #62 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Excel on aero resistance and power
Dear Steffen707,
I have the spreadsheet but cannot open it myself. I īdonīt have the proper program.
I think I saved it with Open Office and then I erased the program.
Give me yr email and I will send it to you anyway.
OldBeaver
Mercedes 300 D turbo 1993
Old 04-20-2012, 01:41 PM   #63 (permalink)
email sent in pm
Old 04-23-2012, 02:10 PM   #64 (permalink)
90 day: 51.82 mpg (US)
Post 57 links to another forum with a spreadsheet available for download. I'm not sure if it's the same one oldbeaver used:
http://ecomodder.com/forum/showthrea...tml#post184492
Old 04-23-2012, 06:04 PM   #65 (permalink)
Tools for drag resistance and such...
Dear MetroMPG,
I used the tools provided by ecomodder here:
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Enter to FORUM, then look for GARAGE & TOOLS
Choose TOOLS and there you are...
Luck !
OldBeaver
Old 04-23-2012, 11:59 PM   #66 (permalink)
The spreadsheet discussed on post 51 isn't the same as the one on the tools section. It is a whole lot more complex, which isn't BAD, but i was hoping to get the simple version found on the tools section.
Old 05-22-2012, 06:52 PM   #67 (permalink)
thank you!
Old 08-20-2012, 11:47 AM   #68 (permalink)
ERTW's Avatar
Bu - '08 Chevrolet Malibu LS
90 day: 32.29 mpg (US)
Fe vs road speed is an inverted bathtub. This spreadsheet is only useful within a small speed range (around 80kph).
Old 11-17-2012, 02:16 PM   #69 (permalink)
Corolla - '88 Toyota Corolla LE
90 day: 32.6 mpg (US)
Hello, Ive been a long time lurker here on this board - a search usually finds the information I'm interested in, so I haven't ever really needed to post.
I am trying to derive a simple (read: very simple - no Crr, Δm, a, etc.) mathematical model for the rate of fuel consumption with regards to air resistance only, assuming constant V and m.
So far I've gotten:
B=(BSFC/ρη)Fd
Where η, efficiency, Fd, drag force, and ρ, energy density, are known.
η=1/(BSFC*ρ) => BSFC=1/(η*ρ)
B=fuel consumption (which I'm ultimately trying to find in gal/100mi).
I figure this would be the correct thread. Am I on the right track? If not, any insight would be great.
Thanks, and nice to finally meet everyone!
Old 11-17-2012, 04:50 PM   #70 (permalink)
fuel consumption
So far I've gotten:
B=(BSFC/ρη)Fd
If you have a baseline mpg at a steady 55-mph,or 70-mph,and have made changes which affect only the drag coefficient,then the following relationships developed by General Motors, may be used with a high degree of confidence:
*A 10% drag reduction @ 55-mph will yield a 5% increase in mpg .
*A 10% drag reduction @ 70-mph will yield a 6% increase.
From here.you can convert into any useful unit of measure.
The relationship presumes a constant BSFC,and it has been reported by others that proper gear-matching is necessary to derive the full benefit of the drag reduction,but thermodynamically,the percentages are correct.
88'rolla (11-18-2012), mikeyjd (09-14-2013)
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
