Old 11-10-2016, 02:20 PM   #2871 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Haha! Totally awesome! Can't wait to get assembling my controller.
Old 11-13-2016, 05:52 PM   #2872 (permalink)
Thanks for the great response i've been looking for crashed leaf or volt but they seem to be hard to find around here. I've been dooing some more research and found that the motor came out of a U.S. electricar back in the mid 90's.
I am looking for a dolphin controller or more documentation so I can interface it with Paul and Sabrina's controller.
The Following User Says Thank You to CoopL For This Useful Post:
MPaulHolmes (11-15-2016)
Old 11-17-2016, 12:38 PM   #2873 (permalink)
PaulH
MPaulHolmes's Avatar
Here's a quick demonstration of 50 amps of battery regen current, which was enough to make it skid to a halt:
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
kalidasbala (12-10-2016), mora (11-17-2016)
Old 11-19-2016, 12:20 PM   #2874 (permalink)
Very Cool!!
Is that the new mostly SMT controller?
Old 11-19-2016, 12:41 PM   #2875 (permalink)
PaulH
Yes!
kits and boards
Old 11-23-2016, 05:05 PM   #2876 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by arber333 View Post
Paul i am working on encoder mount now and will mount it the same way as resolver is mounted. Now since i have open collector A, B, Z signals i will have to pull them up to 5V with resistors. Can you suggest R value? I see you use 1K resistors to protect micro pins. Do i use 1K also, or could i use 4.7K. Or should i rather use 470R to make ports react faster? Or would you recommend changing input resistors from 1K to 470R?
RLS has 20mA draw limit for their encoder chip.
4K7 is fine, in my opinion. The encoder does not need to react fast - it needs to react consistently. If the signal rises high enough to qualify as ON and falls low enough to qualify as OFF that's all that's required. It can look like a sine wave or a triangle even. But channel A needs to rises before channel B one direction, and channel B rises before channel A the other direction. My cables were made of unshielded category 5 solid-core 22 AWG wire, they were unshielded, I used a voltage divider on the signals since it was fed with 24V and the micro wanted a 5V signal, and there were contacts held together with duct tape. It worked fine for testing ... I would do it a bit better than that for the permanent install ... The scope showed is was very noisy, but it worked.
Old 11-24-2016, 12:31 AM   #2877 (permalink)
PaulH
Yes I agree with thingstodo. 4.7k is a good pull up value.
kits and boards
Old 11-26-2016, 11:15 AM   #2878 (permalink)
Hi all,
Can you please guide me with making a 10 to 20 Kw controller for use in motorcycles.
What parts do I have to downgrade and will it be ecnomically viable ?
I am following Paul's instructions on instructables .
Old 11-26-2016, 03:43 PM   #2879 (permalink)
PaulH
What voltage will you be using?
kits and boards
Old 11-26-2016, 11:01 PM   #2880 (permalink)
72 v 40 Ah or any configuration for 3kWh battery.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
