Old 11-10-2016, 04:13 AM   #2881 (permalink)
Leaf motor
Hi all
I am a bit confused. I taught Leaf motor was 4 pole PMSM. It states that here...
https://avt.inl.gov/sites/default/fi...nissanleaf.pdf
But i got other sources that say otherwise! Like this paper here it suggest that stator is 8 pole winding.
http://energy.gov/sites/prod/files/2...ess_2013_o.pdf
From your experience what is correct then?
Old 11-10-2016, 08:13 AM   #2882 (permalink)
PaulH
MPaulHolmes's Avatar
It is 8 pole (4 pole pairs). Here's a video I just finished with testing it on our go-kart. I don't think it would spin if the pole pairs were wrong:
kits and boards
The Following 4 Users Say Thank You to MPaulHolmes For This Useful Post:
dave koller (11-10-2016), kalidasbala (12-10-2016), mora (11-10-2016), thingstodo (11-15-2016)
Old 11-10-2016, 08:51 AM   #2883 (permalink)
Whohoho! Very good! Only 50A phase 96Vdc and no shaking. I want to spin my motor now!!!
Seriously you should consider adding one switch to define direction. Put it on pin 10 maybe and we will cheer you try it .
The Following User Says Thank You to arber333 For This Useful Post:
MPaulHolmes (11-10-2016)
Old 11-10-2016, 03:20 PM   #2884 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Haha! Totally awesome! Can't wait to get assembling my controller.
Old 11-13-2016, 06:52 PM   #2885 (permalink)
Thanks for the great response i've been looking for crashed leaf or volt but they seem to be hard to find around here. I've been dooing some more research and found that the motor came out of a U.S. electricar back in the mid 90's.
I am looking for a dolphin controller or more documentation so I can interface it with Paul and Sabrina's controller.
The Following User Says Thank You to CoopL For This Useful Post:
MPaulHolmes (11-15-2016)
Old 11-16-2016, 08:38 AM   #2886 (permalink)
Leaf Blog
I will try to show how i assemble and test my inverter here. Later i will probably try to log my second car conversion. Have fun reading.
https://leafdriveblog.wordpress.com/
The Following 2 Users Say Thank You to arber333 For This Useful Post:
mora (11-17-2016), MPaulHolmes (11-16-2016)
Old 11-17-2016, 01:38 PM   #2887 (permalink)
PaulH
Here's a quick demonstration of 50 amps of battery regen current, which was enough to make it skid to a halt:
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
kalidasbala (12-10-2016), mora (11-17-2016)
Old 11-19-2016, 01:20 PM   #2888 (permalink)
Very Cool!!
Is that the new mostly SMT controller?
Old 11-19-2016, 01:41 PM   #2889 (permalink)
PaulH
Yes!
kits and boards
Old 11-23-2016, 06:17 AM   #2890 (permalink)
encoder-ticks is one of the variables you can set, so it's not a big deal no matter what you pick. I think 256 ticks is plenty. That would turn into 1024 ticks per revolution after the dspic got a hold of it. And with an open collector, wouldn't it take a little time to get pulled up or down?
Paul i am working on encoder mount now and will mount it the same way as resolver is mounted. Now since i have open collector A, B, Z signals i will have to pull them up to 5V with resistors. Can you suggest R value? I see you use 1K resistors to protect micro pins. Do i use 1K also, or could i use 4.7K. Or should i rather use 470R to make ports react faster? Or would you recommend changing input resistors from 1K to 470R?
RLS has 20mA draw limit for their encoder chip.
tnx
Arber
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 11:55 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 02:59 PM
