Old 03-13-2010, 05:31 AM   #3161 (permalink)
PaulH
MPaulHolmes's Avatar
All you people in other countries stay up really late! hahahaha.
Wait, strike that, reverse it. Yes, it's 1:30am, and my 2 year old son is still going strong.
kits and boards
Old 03-13-2010, 03:44 PM   #3162 (permalink)
Originally Posted by jackbauer View Post
ludiagsm , This guy would solve your problems in one easy step:
IGBT Modul SEMIKRON SKM400GAL 128D on eBay (end time 07-Apr-10 15:18:49 BST)
Hi jackbauer that igbt is on very good price 10x
I have one more question to all ,can i see somewhere schematic on mr Paul Homes controller. I thing that it is time to build some real thing.
Old 03-13-2010, 04:07 PM   #3163 (permalink)
Mark Weisheimer
Ludiagsm,
Here is the link to the Revolt WiKi
Open ReVolt - EcoModder
If you read through all 3XX pages of this thread, you will find a video of
JackBauer testing his IGBT module power section. I think that his first tests
were using a starter motor just like you did. Check out all of the video's that
are linked in the thread and you will sometimes have to pick yourself up from the floor from laughing. You will get to see that these fellows have a sense of humor and they also show a lot of good ideas.
Cheers
Mark
The Following User Says Thank You to Weisheimer For This Useful Post:
ludiagsm (03-13-2010)
Old 03-13-2010, 08:13 PM   #3164 (permalink)
can someone tell me what is ,
example;
2oz copper board , can someone explain me relationship with european standards , what is the thicness of the copper in mm ?
Old 03-13-2010, 09:03 PM   #3165 (permalink)
peja1971's Avatar
Bela rada - '09 Peja Bela rada
I must replay you here because I have only 6 posts and I can't send you PM
Originally Posted by Weisheimer
Hi Peja,
Perhaps a few questions first.
What is the voltage of your system?
120v - 10 12v Lead acid battery for now
What is the AH rating for your batteries?
100ah
Which motor are you using for your vehicle?
Is it a series wound DC motor with A1, A2, S1 and S2 leads?
Or, is it a permanent magnet motor with only 2 leads?
serial wound DC, two terminals
What is the voltage and current rating for the motor?
72v, 85a (I think), 2200 rpm
The Mosfets can be driven with a 0 to 12V signal quite nicely.
12 volts will turn the Mosfets on, and 0V will turn them off.
I know that, I ask which voltage is the best to trigger gates for my case (40 pcs IRFP260N), is it the best to be 12v or 20v or some other?
You have seen the drive used in the Curtis controller.
Take a look at a Leeson controller too.
They are using 40106 schmitt triggered drive (U1) that will
give a solid square wave drive to the gates of the IRFZ44 Mosfets.
This is some low end kontroler I think, I have PIC in my control board.
Look at the Mosfets beside the motor, they have
tied the gate to the source and are thus using them
as Diodes for the freewheeling diode.
You could do that too.
Yes, I'll do that
http://www.leeson.com/TechnicalInfor...dcadjspeed.pdf
I have sent this as a PM since it is not discussing the REVOLT controller.
OK
Cheers
Mark
Thank you
Peja
Old 03-13-2010, 11:32 PM   #3166 (permalink)
example;
Each "ounce" of copper is 35um so 2oz. boards have a 70um thick layer of copper.
John M.
Owner
CamLight Systems
The Following 2 Users Say Thank You to CamLight For This Useful Post:
mpgmike (01-14-2022), struja (03-14-2010)
Old 03-14-2010, 12:49 AM   #3167 (permalink)
apowers's Avatar
Hi Paul
I have not found any shorts. I followed every line on the schematic to check for continuity. Every line. I am getting power to the chip. You know I might not have a programed chip. I thought I had the old one. Maybe not. I could try the chips I have in the truck to see. Or take the one in the truck and try it in this board.
Thanks
Alvin
Old 03-14-2010, 12:54 AM   #3168 (permalink)
PaulH
I bet it's the chip then. Let me know if you need another chip. I'll send you one.
kits and boards
Old 03-14-2010, 01:04 AM   #3169 (permalink)
Hey mr Paul can you send one pic for me what will be the cost?
Old 03-14-2010, 01:05 AM   #3170 (permalink)
apowers's Avatar
I'm hoping that's all it is. Thanks I'll let you know.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
