Old 02-10-2013, 11:46 AM   #6001 (permalink)
Paul, How ya doing on the shop?
Old 02-10-2013, 11:50 AM   #6002 (permalink)
PaulH
MPaulHolmes's Avatar
Just added calking on the roof to make it waterproof. Well, there are a couple seams left. Then I got this rubbery roll on stuff to protect the wood. I got the mill connected yesterday, but I have stuff everywhere. Today or tomorrow I'm going to get some 24" x 8foot plywood for shelving, then I can start organizing things. Right now I'm tripping all over everything.
kits and boards
Old 02-10-2013, 12:54 PM   #6003 (permalink)
Finally, my controller is mostly ready. The good news is, didn't let the magic smoke out, but it's acting weird.
At the first try with the battery and motor connected, i was able to "accelerate"... once, since it's start on full throttle every time i switch it on.
Near full throttle i can slow i down and i get fb=08 fault code.
So, could You tell me what did i do wrong?
I've attached the config and a part of the log and a short video.
Name:	Screenshot from 2013-02-10 15:13:04.png
ID:	12455 Click image for larger version
Name:	Screenshot from 2013-02-10 15:22:08.png
Old 02-10-2013, 09:21 PM   #6004 (permalink)
PaulH
OK, with everything disconnected, check resistance from M- to B-. But first, pray that it is large...
kits and boards
Old 02-11-2013, 05:03 AM   #6005 (permalink)
62.5kOhm
I can stop the motor if i give almost full throttle, then i get an error and the motor start spinning full on again. Working, just kinda opposite way....
Here is the log of 0-full throttle two times with a 12V bulb and 5A bat-amps-lim.
At 0 throttle the light is on, as i turn the pot it's getting dimmer, then throw an error (08) and the light is full on again.
Code:
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0257 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=002 PW=000 HS=0258 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0713 FB=00 BA=000 AH=000.0
TR=053 CR=088 CF=004 PW=049 HS=0258 RT=0655 FB=00 BA=000 AH=000.0
TR=095 CR=031 CF=002 PW=092 HS=0258 RT=0635 FB=00 BA=000 AH=000.0
TR=178 CR=017 CF=002 PW=149 HS=0258 RT=0596 FB=00 BA=001 AH=000.0
TR=202 CR=016 CF=002 PW=163 HS=0258 RT=0585 FB=00 BA=001 AH=000.0
TR=281 CR=013 CF=002 PW=198 HS=0258 RT=0548 FB=00 BA=001 AH=000.0
TR=293 CR=012 CF=002 PW=208 HS=0258 RT=0542 FB=00 BA=001 AH=000.0
TR=304 CR=010 CF=002 PW=236 HS=0258 RT=0537 FB=00 BA=001 AH=000.0
TR=304 CR=010 CF=002 PW=244 HS=0258 RT=0537 FB=00 BA=000 AH=000.0
TR=304 CR=009 CF=002 PW=268 HS=0258 RT=0537 FB=00 BA=001 AH=000.0
TR=304 CR=009 CF=002 PW=276 HS=0258 RT=0537 FB=00 BA=000 AH=000.0
TR=357 CR=008 CF=000 PW=296 HS=0258 RT=0511 FB=00 BA=000 AH=000.0
TR=378 CR=008 CF=002 PW=303 HS=0258 RT=0502 FB=00 BA=001 AH=000.0
TR=415 CR=007 CF=002 PW=322 HS=0258 RT=0484 FB=00 BA=000 AH=000.0
TR=430 CR=007 CF=002 PW=328 HS=0258 RT=0478 FB=00 BA=001 AH=000.0
TR=472 CR=007 CF=002 PW=345 HS=0259 RT=0458 FB=00 BA=000 AH=000.0
TR=487 CR=007 CF=002 PW=350 HS=0258 RT=0451 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=368 HS=0259 RT=0430 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=372 HS=0258 RT=0423 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=387 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=392 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=000 PW=408 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=000 PW=413 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=429 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=434 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=448 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=452 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=467 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=471 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=486 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=490 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=505 HS=0259 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=000 CF=007 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0259 RT=0429 FB=08 BA=000 AH=000.0
TR=504 CR=000 CF=004 PW=000 HS=0259 RT=0443 FB=08 BA=000 AH=000.0
TR=398 CR=000 CF=004 PW=000 HS=0259 RT=0493 FB=08 BA=000 AH=000.0
TR=378 CR=000 CF=004 PW=000 HS=0259 RT=0502 FB=08 BA=000 AH=000.0
TR=376 CR=000 CF=002 PW=000 HS=0259 RT=0503 FB=08 BA=000 AH=000.0
TR=157 CR=000 CF=004 PW=000 HS=0259 RT=0607 FB=08 BA=000 AH=000.0
TR=087 CR=000 CF=004 PW=000 HS=0258 RT=0639 FB=08 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0713 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0258 RT=0714 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0715 FB=00 BA=000 AH=000.0
TR=000 CR=000 CF=004 PW=000 HS=0259 RT=0714 FB=00 BA=000 AH=000.0
TR=042 CR=084 CF=004 PW=028 HS=0258 RT=0660 FB=00 BA=000 AH=000.0
TR=123 CR=035 CF=002 PW=086 HS=0259 RT=0621 FB=00 BA=000 AH=000.0
TR=332 CR=018 CF=002 PW=146 HS=0259 RT=0524 FB=00 BA=001 AH=000.0
TR=376 CR=016 CF=002 PW=160 HS=0258 RT=0503 FB=00 BA=001 AH=000.0
TR=476 CR=013 CF=002 PW=196 HS=0259 RT=0456 FB=00 BA=001 AH=000.0
TR=502 CR=012 CF=002 PW=206 HS=0258 RT=0444 FB=00 BA=001 AH=000.0
TR=511 CR=011 CF=002 PW=234 HS=0258 RT=0417 FB=00 BA=000 AH=000.0
TR=511 CR=010 CF=002 PW=242 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=009 CF=002 PW=266 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=009 CF=002 PW=274 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=008 CF=002 PW=295 HS=0258 RT=0411 FB=00 BA=000 AH=000.0
TR=511 CR=008 CF=000 PW=301 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=008 CF=002 PW=321 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=007 CF=002 PW=327 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=343 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=349 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=007 CF=002 PW=365 HS=0258 RT=0412 FB=00 BA=001 AH=000.0
TR=511 CR=006 CF=000 PW=370 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=384 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=002 PW=389 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=002 PW=403 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=006 CF=002 PW=408 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=006 CF=000 PW=423 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=428 HS=0258 RT=0412 FB=00 BA=002 AH=000.0
TR=511 CR=005 CF=000 PW=441 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=446 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=459 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=002 PW=464 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=478 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=483 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=497 HS=0258 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=005 CF=000 PW=502 HS=0257 RT=0412 FB=00 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0258 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0257 RT=0412 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=002 PW=000 HS=0257 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0411 FB=08 BA=000 AH=000.0
TR=511 CR=000 CF=004 PW=000 HS=0257 RT=0440 FB=08 BA=000 AH=000.0
TR=485 CR=000 CF=004 PW=000 HS=0257 RT=0452 FB=08 BA=000 AH=000.0
TR=391 CR=000 CF=004 PW=000 HS=0257 RT=0496 FB=08 BA=000 AH=000.0
TR=340 CR=000 CF=004 PW=000 HS=0257 RT=0521 FB=08 BA=000 AH=000.0
TR=106 CR=000 CF=004 PW=000 HS=0257 RT=0630 FB=08 BA=000 AH=000.0
TR=042 CR=000 CF=004 PW=000 HS=0257 RT=0660 FB=08 BA=000 AH=000.0
Old 02-11-2013, 09:48 AM   #6006 (permalink)
PaulH
FB = 8 means zero current, but max pwm duty occurred. Measure the voltage from any of GR1 through GR10, to PH1 or PH2. Do this while it's zero throttle through full throttle.
Then, measure voltage across R15, from zero throttle to full throttle.
-Paul
kits and boards
Old 02-11-2013, 10:30 AM   #6007 (permalink)
-Paul
GR-PH at 0 throttle = 12V
GR-PH at full throttle = at 0.3V got an error and went to 12V
R15 at 0 = 0V
R15 at full = 3.2V
Old 02-13-2013, 08:30 AM   #6008 (permalink)
EVVette - '71 Chevy Corvette Coupe
Just thought I would post this here to.
Im placing orders for parts and boards for my 3 IGBT driver board if anybody is interested. Here is the link how to order.
http://ecomodder.com/forum/showthrea...tml#post355964
Also, here is some info about it:
http://ecomodder.com/forum/showthrea...tml#post294581
Picture:
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 02-15-2013, 05:57 AM   #6009 (permalink)
-Paul
R15 at 0 = 0V
R15 at full = 3.2V
Any thoughts on that?
Z
Old 02-15-2013, 07:34 AM   #6010 (permalink)
PaulH
Can you read the part number for U6 and U7?
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
zsnemeth (02-15-2013)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
