Old 07-13-2014, 10:49 AM   #6671 (permalink)
EV Connoisseur
So there is no problem?
Old 07-13-2014, 11:00 AM   #6672 (permalink)
PaulH
MPaulHolmes's Avatar
There is a hardware overcurrent protection circuit for each separate IGBT. I'm not doing anything with the other 2 current feedbacks at the moment inside the micro.
kits and boards
Old 07-13-2014, 11:19 AM   #6673 (permalink)
EV Connoisseur
Okay.. I think the best thing to do is leave the setting at 100A and drive it around.. and monitor it closely.. with separate devices
The Following User Says Thank You to flores For This Useful Post:
MPaulHolmes (07-13-2014)
Old 07-14-2014, 02:08 AM   #6674 (permalink)
PLUGnGO
jedsmd's Avatar
At last the home move is winding down and I can work on my new controller.
Today I got it into the truck and fully connected up
A lot of orange cable going this way and that
Right now the controller is setting above a fan that feeds air through a gap under the controller. I don't know if that will be enough cooling for my around town driving style. I will monitor the plate temperature and add a heatsink if required.
Low voltage end with cover open, note the relay added to the contactor circuit to isolate the 24volt controller from the 12 volt contactor coil.
So when I fire it up absolutely nothing happens
Paul is possible I can get some software?
The Following User Says Thank You to jedsmd For This Useful Post:
MPaulHolmes (07-14-2014)
Old 07-14-2014, 03:18 AM   #6675 (permalink)
PaulH
Minor details. I guess it would be good to program it first. I'll send you a hex file tomorrow morning. I probably just had some debug mode code on it at the moment.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
jedsmd (07-14-2014)
Old 07-14-2014, 02:38 PM   #6676 (permalink)
PaulH
Oh crap. I forgot that your throttle is inverted. I almost sent you the wrong code. PHEW. I'll try to find some time today to make the modification so it goes 5k = zero throttle and 0k = max throttle. There will be a little dead zone, so as to guarantee that the throttle contactor closes well BEFORE the throttle is considered nonzero. You definitely don't want the throttle to be nonzero, and the poor pwm ramping up to 100% in the vain attempt to see a nonzero current feedback (no current can flow when the contactor is closed).
kits and boards
jedsmd (07-14-2014)
Old 07-14-2014, 03:26 PM   #6677 (permalink)
EV Connoisseur
Wouldn't it be a good idea to make that configurable?
Old 07-14-2014, 03:30 PM   #6678 (permalink)
PaulH
Well, now that you mention it, yes! That would be good. I had been half-heartedly trying to keep things as similar as possible to the other serial structure, but I've had to depart from it somewhat. So I may as well add that!
kits and boards
flores (07-14-2014)
Old 07-14-2014, 11:08 PM   #6679 (permalink)
Irony
Originally Posted by xtian999 View Post
Yes, it is like a pc fan, only much bigger. About 6" across and 2" thick. I will splice in a plug for it and see what happens. If it causes the controller to fry, then we will know that it was a big fan of irony.
Reading through the whole thread. This one killed me!
You guys are funny guys.
The Following User Says Thank You to Sunny2 For This Useful Post:
Old 07-15-2014, 08:19 AM   #6680 (permalink)
EV Connoisseur
btw.. I ordered this RS232 Shield - floris.cc so I can start building that web interface netduino thing.
MPaulHolmes (07-15-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
