Old 08-13-2008, 09:10 AM   #11 (permalink)
Roman's Avatar
Golf D - '83 Volkswagen Golf GL
90 day: 42.79 mpg (US)
I found a shop where they sell rubber strips from 2inch. I will use one of those to make an airdam. Rubber is flexible so when i hit somethink it wil bend. Maybe is that also an idea for your car.
NOW INTERACTIVE! Joystick controls Fry's left ear.
Old 08-13-2008, 12:01 PM   #12 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
A problem with rubber is that it can bend too much or worse, wobble and oscillate under airflow and that can create more turbulence than you may care for.
Since you've go so much of the front belly panned, a front air dam is probably not necessary. Front/side/rear wheel fairings might be helpful but conversely will entail more work on your part. (My Scion also has those little tabs ahead of the front wheels -- also a mini pan under the fender)
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-13-2008, 01:14 PM   #13 (permalink)
Hi,
A general comment about inside vs outside blocks:
I have noticed a (small) difference between taping (the outside) in courses starting at the bottom of the grill vs starting at the top. The only difference is the direction of the overlap -- the air is catching and lifting the seam if you start at the bottom, and this then drags a bit more!
So, if that small detail makes a difference, then blocking the inside of the grill can't be as effective as blocking the outside.
Old 08-13-2008, 01:17 PM   #14 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Heck of a job! Looks great and kudoos on the recycle!!!
Old 08-13-2008, 02:33 PM   #15 (permalink)
EcoVibe - '07 Pontiac Vibe base
90 day: 38.14 mpg (US)
That's sort of what I was thinking after reading a bunch of car magazine and other aerodynamic articles. It will likely increase my overall frontal area and counter the gains I'd see if I do the full belly pan.
Hi,
That's interesting on the overlap of the tape. I was thinking of trying some test runs with painters tape over the upper grill.... then with both grills taped ... and then both grills and fogs covered to see if the MPG changes at all. So go from bottom up .... that makes sense ... especially if the tape starts to lift at all.
Old 08-27-2008, 12:50 PM   #16 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Very, very professional looking.
I really like these 'stealth' factory looking mods. that you guys are doing.
Thanks for posting pictures.
Old 08-27-2008, 01:13 PM   #17 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Originally Posted by Markmysite View Post
I'm surprised that they're are not more Vibe/Matrix users doing the aero mods. I have found tons of info on other cars, but not much on these.
We're on our own, Markmysite.
Be watching for my new grilleblock...it's almost done..
-Terry
Old 06-07-2009, 12:07 PM   #18 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I'm wondering if anyone has thought of my idea for a grille block.
I was planning on using insulating foam sealant (the kind you get in a can) and squirting it into the gaps between the gaps on the grille. After time to let it harden, I would trim off the excess with a knife, paint it black to match the rest of the grille, then reinstall it. THe beauty of this idea, other than the cheapness of it, is it wouldn't be hard to push the foam out of the grille if I go into an overheating situation. But done right, I think it would look very clean.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 12-26-2009, 01:33 PM   #19 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the picture links are dead!!!
Old 12-26-2009, 05:43 PM   #20 (permalink)
The PRC.
If anyone has copies of the pics upload them to the website as part of their posting, that way the site "integrity" (as in you can come back in the future and see it as it is now) is preserved. We get no zombie threads that way and info is shared in the most effective way.
The Following User Says Thank You to Arragonis For This Useful Post:
ShadeTreeMech (07-30-2010)
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 12:30 AM
Grill Block Revision - Work in Progress Photos gascort Aerodynamics 15 07-10-2008 11:43 PM
