Old 10-26-2017, 10:46 AM   #21 (permalink)
Cool Love this....
I simply love this... what you've done to the car. I've always 'loved' the Speedster look, like Bonneville Salt Flats racecar, or like the 1948 Merc Hotrod from Cobra, with the white letter tires added.
If I find myself in the position to buy a Volt, damn straight i'm gonna add the same effects to the body like the digital pic above.
Modding a Volt as a Hotrod? Definately.... ^^
Kimonoskunk, aka Todachi <><
1 Corinthians 15 : 1-4, 51-52
This image has been resized. Click this bar to view the full image. The original image is sized 792x564.
It's always fun to see mods for the Volt.
Old 10-26-2017, 11:11 AM   #22 (permalink)
90 day: 51.82 mpg (US)
Too bad so many of the other images in this thread were broken by the Photobucket fiasco.
Kimonoskunk (10-26-2017)
Old 10-26-2017, 12:17 PM   #23 (permalink)
I wonder why I didn't post this one, a Prius with a 36hp VW engine and a Porsche 911 cooling fan mounted on the crankshaft. And a full set of wheel spats.
Picture Added 03-27-2013 01:32 PM
aerohead (10-28-2017)
Old 10-26-2017, 08:44 PM   #24 (permalink)
Cool I agree
Thats why I use Dropbox
Old 10-26-2017, 09:16 PM   #25 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
It's probably even good for almost 30mpg on the highway.
Old 10-27-2017, 12:08 PM   #26 (permalink)
It's notional, but the 36hp Beetle is (barely) capable of 40mpg in favorable circumstances. This would have the same weight as a stock Beetle and 25/40ths the aerodynamic drag.
Plus the wheel spats. I think the biggest knock is the fan should be foreshortened. It looks cock-eyed.
Old 10-27-2017, 02:01 PM   #27 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
It's notional, but the 36hp Beetle is (barely) capable of 40mpg in favorable circumstances. This would have the same weight as a stock Beetle ...
Doesn't a stock beetle weight about 1600lbs?
And a stock gen 2 Prius around 3000lbs? I can't imagine the difference between the Prius engine/transmission/hybrid system and the Beetle engine is more than 500lbs.
Old 10-28-2017, 01:02 AM   #28 (permalink)
1750-2000lb. I guess the Prius battery is ±100lb. I did calculation for a full EV conversion of a Beetle and I had a budget of 450lb for the batteries.
There is probably a bit of weight in airbags and such.
And I included the 2013 post date to show it's not really up-to-date.
Old 10-28-2017, 09:48 AM   #29 (permalink)
Prius battery is 64lbs, not sure about the other accessories. Car is just shy of 3000.
Old 10-28-2017, 11:46 AM   #30 (permalink)
Beetle Cd is ~0.41, Prius is 0.25-6.
I can delete the picture if you insist.
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
GM admits the Volt concept car's aerodynamics suck MetroMPG Aerodynamics 16 12-13-2008 01:16 PM
Chevy Volt and GM Get Big Boost From $700B Bailout Vote Today Matt Herring EcoModding Central 15 10-09-2008 04:20 AM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
