01-12-2021, 03:10 AM
#71 (permalink)
Ultimate Fail
Originally Posted by JulianEdgar
The movie is good but the real story is better.
I watched the movie hoping for more on the machine than the man, but that was not the case.
The same with Ford vs. Ferrari.
The Following User Says Thank You to Cd For This Useful Post:
01-12-2021, 03:14 AM
#72 (permalink)
For Ford vs Ferrari, read this.
But again not much tech info - but the *real* story, not the film version.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
01-12-2021, 09:36 AM
#73 (permalink)
Moderator
Boots and bonnets are UK usage, not really Australian as such. We take after the UK in spelling and word usage (and system of government too, actually).
I took both those quizzes after I posted, and they're not accurate--spelling errors like "emergency break" but also outright incorrect distinctions (e.g. we call them "lawyers" in the US).
The Following User Says Thank You to Vman455 For This Useful Post:
01-12-2021, 11:27 AM
#74 (permalink)
Aero Wannabe
Back on topic?
Today I have found two papers that cover turning vanes.
One paper showed that aerofoil sections are much better than flat plates (what I'd found in my testing) and the other showed that really good gains can be made on older cars' A-pillars by the use of turning vanes (which also supports what my tuft testing showed).
So I'd like to fit them to my Insight, but the same old problem remains. No matter how hard I look, I cannot find an aerofoil-shaped aluminum or plastic extrusion that I can easily buy by the metre that's roughly the right size.
If it is not possible to weld 2 sections together to make the length needed, I have had surprisingly good results with J-B Weld, a very strong epoxy. It would be best to add some dowels in the hollow cavities for alignment and support.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
01-12-2021, 04:25 PM
#75 (permalink)
Model aircraft construction techniques are on point. Foam board wrapped around a spar.
.Necessity is the mother of invention, but simplicity is it's favorite aunt --Amish proverb
01-13-2021, 10:13 AM
#76 (permalink)
Something has been bothering me here: are these reduction because of the airfoil shape or are they because you are increasing the radius of the pillar?
01-13-2021, 03:21 PM
#77 (permalink)
I don't know.
But I know that the tuft pattern changed when the inlet/outlet ratio of the guide was changed, and that a curved plate of the same dimensions as the aerofoil did not cause the better tuft pattern, even when its angle was changed in the same way as the aerofoil.
01-14-2021, 05:30 AM
#78 (permalink)
Long time lurker
Or hotwire some foam, and use a carbon/wood spar. 3.44 in below video I found. Add a cutout for the spar in the template.
I think this is a potentially useful technique in aerodynamic modifications, maybe only in specific areas but useful nonetheless.
The Following 2 Users Say Thank You to AeroMcAeroFace For This Useful Post:
02-06-2021, 10:44 PM
#79 (permalink)
The hood turning vaine/ slat (? Terminology?) used by a manufacture discused priviously in a nother thread have the same needs as far as considering the angles, span:cord ,some one sugested to mix airfoil with VG/moddified VG mounts set up as "air fence" to prevent span wise seperation as your angle of attack is more of a swept wing leading edge@ ~45° on 2 plains to the direction of flow...
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
02-06-2021, 11:11 PM
#80 (permalink)
The 0.125x3" flat wing accrost the hinges on my cap was welded with ~2.5-5°angle of attack to :
Create a small amount of converging duct.(1/8" closure over only3" isnt going to do much if anything.)
Be above the turbulance caused by the cab cap gap.
Cause a slight down wash promoting attachment sooner.
my tuft test video showing attached flow Downstream
Julian this looks to be a proper place for you to apply the eroding clay technique.
Here's a picture of the inverse of eroding clay. Additive aerodynamic sculpting.
Pay close attention to the upper screw holes in a license plate that allowed are passed through the bumper due to the pressure differential the scallops and the shape of the entries.
Former
87' Hyundai Excel
