Old 11-07-2010, 05:35 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Please help TODAY! Looking at a 06 Civic Hybrid with a weird sound.
Hey gang. Hope alls well!
Thinking about picking up a 2006 Honda Civic Hybrid
Checked it out today and it looks good.
1 Owner. Clean title. 60k miles. Maintained ok. Good price.
Only thing that Im not certain about is a loud whirling noise.
(kinda does sound like a hybrid engine being cranked)
It doesnt sound bad, just different as its the first hybrid ive been in.
(Its very quiet in my Echo)
So do all civic hybids sound like that?
Past Present Future?
Old 11-07-2010, 06:57 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The inverter, which is located behind the rear seats, gives off a high-pitched whine during assist and regen. It makes the same sound wihle you're cranking the engine. Mine isn't "loud", but you can hear it if you listen for it. It's pretty much silent when you're not on the assist/regen.
The Following User Says Thank You to RobertSmalls For This Useful Post:
alohaspirit (11-07-2010)
Old 11-07-2010, 07:35 PM   #3 (permalink)
Grasshopper
darn, strike that Rob
ive been in a 1st gen insight
(which wasnt that loud at all)
im trying hard to describe the sound so bear with me
it sounds kinda like an 15 year old dryer that could use a drop of WD40
(not whisper smooth but noticeable when youre on the gas)
i could hear it with the radio on soft and 2 people talking in the backseat
Old 11-07-2010, 07:55 PM   #4 (permalink)
Left Lane Ecodriver
So, probably a bad bearing somewhere?
Well, it's not the alternator bearing . It's hard to tell from 6000mi away, but if I were you, I'd pop the hood and attempt to determine whether it's coming from the transmission (CVT, I don't like 'em because I can't shift them or repair them myself) or the front of the engine (probably an easy fix).
Can you take it to an independent mechanic in the morning?
Old 11-07-2010, 08:05 PM   #5 (permalink)
Grasshopper
shes taking it to the dealer for an IMA update in the morning
i was thinking about going there too and asking them if it they could identify it
(not sure how thats going to work as im not the owner)
ive done the research and civi hybrids have had problems with wheel bearings
($150-$500 each depending on the shop you go)
ive been in a lot of cars though and it sure didnt sound like a wheel bearing
(it could be though)
Old 11-07-2010, 08:15 PM   #6 (permalink)
Left Lane Ecodriver
When you're trying to locate a sound, it helps to shift to neutral, and try various engine speeds including 0RPM. Also pay attention to whether its pitch corresponds to vehicle speed, engine speed, or some specific load.
Old 11-07-2010, 08:20 PM   #7 (permalink)
Grasshopper
thanks
(only heard it while driving)
and if anyone can chime in anything, feel free
Old 11-08-2010, 06:29 PM   #8 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Check the A/C clutch, with the engine running take a look down in the front passenger side of the engine, right net to the radiator, you will see a belt going around a pulley on the A/C clutch and if the bearing is bad you will notice the pulley sliding back and forth, or you can try turning the A/C on and see if it goes away or changes.
Old 11-08-2010, 11:18 PM   #9 (permalink)
Grasshopper
maybe its that im not used to hearing the hybrid regen
an example is:
where you ride a bike
(which is generally quiet. all you hear is chain and tire noise)
then you hook up a mini-generator to power your headlamp
(its that intermittant winding sound im not used to)
seems to be around 30mph - 50 mph when i gas and coast
Old 11-08-2010, 11:31 PM   #10 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Now it sounds like the inverter again.
They sound like a cross between a whine and a hum.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Aero differences between my 2008 Civic LX and the Hybrid...mod inspiration? KJSatz Aerodynamics 11 05-25-2013 06:26 AM
Civic Hybrid MPG class action lawsuit settled... now heading to small claims court MetroMPG Hybrids 75 06-06-2012 05:08 PM
Any info on 1st gen civic hybrid wheels? weight, value. Ryland EcoModding Central 1 04-11-2010 08:44 PM
Should I buy this civic Hybrid? jasonck08 General Efficiency Discussion 5 11-03-2009 06:33 PM
New Honda Insight has higher cD than Civic Hybrid winkosmosis Aerodynamics 10 04-19-2009 06:00 AM
