Old 11-02-2012, 06:24 PM   #21 (permalink)
Coroplast Engineer
slowbro's Avatar
AV - '04 Chevy Aveo sedan - not LS
90 day: 34.28 mpg (US)
Jolteon - '00 Honda Insight MT
90 day: 77.25 mpg (US)
I think it makes more sense when you look at speed.
If I drove 30 mph for the first half of a 30 mile trip, and 15 mph for the second half, my average speed is NOT (30+15)/2= 22.5 mph.
Instead, it took half an hour for the first half and an hour for the second half, so you're average speed is actually:
(30 miles)/(1.5 hours)= 20 mph.
The key is in the denominator you cannot add 30 mph to 15 mph, because even though the miles driven is consistent, the time taken is not. You have to find the least common denominator to add them together.
However,
If I drove 30 mph for 2 hours and 15 mph for another 2 hours.
(30 mph+15 mph)/2= 22.5 mph does work because the denominators (time) are the same.
You can check that:
(60 miles driven + 30 miles driven)/4 total hours= 22.5 mph, which is the same.
So yes it would make sense to switch to (fuel used/mile) since our commute distances generally stay the same. A one mile road tends to not change in size from day to day. What a strange world that would be.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
Old 11-02-2012, 06:34 PM   #22 (permalink)
Coroplast Engineer
slowbro's Avatar
About the hybrid scenario,
Yeah. The idea is to use as little fuel as possible up the hill, because that is where your losing the vast majority of your fuel economy. That is just one of the advantages of having a hybrid.
AV Build Thread
Old 11-05-2012, 04:38 AM   #23 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Amazing site! I foresee a tool to calculate the best MPG routes with this info + speed limits (user entered), stop signs etc.
Orignal Route to work..
I always get a tiny bit better on the trip to work, I can see why now... I'm going down hill the last 40% of the trip ^.^, need to cut that dang hill out of the middle... lets see the 2nd route I found lately..
Yea.... MUCH better looking.. too bad it is right though town....
I need to learn how they pull that info from google maps so I can figure in where stopsigns, traffic lights, etc are at.
Must.... find.... better.... route....
EDIT:
I'm a computer nut... you should download the images instead of linking direct to the site, I can view the routes etc with a small url edit.
ID:	11805   Click image for larger version
Old 11-06-2012, 07:25 PM   #24 (permalink)
n00b
stimpsonjcat's Avatar
stimpsF150 - '01 Ford F-150 Supercrew
90 day: 16.5 mpg (US)
shifty - '12 Mazda 3 i-touring
90 day: 38.02 mpg (US)
And no real alternate routes.
15 red lights in 20 miles, 25 possible stops including stop signs.
Old 11-06-2012, 09:37 PM   #25 (permalink)
only 200ft elevation between top and bottom isn't terrible. I've learned that the biggest factor is the grade, which you can view on the website. The maximum negative average grade. Hills that aren't too steep, followed by long shallow negative grade just enough to keep momentum are ideal.
Everyones graph has a different scale with regard to elevation. Even if it looks terrible, they don't scale distance in miles to "look" equal in regard to feet of elevation.
I try to be helpful. I'm not an expert.
Old 11-06-2012, 11:12 PM   #26 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Here is mine, if it will work. This is my main commute, I also have a much shorter, 9 mile trip to school. Which makes up usually a little more than half my tank, and this is my other half of the tank.
Distance: 54.1 mi
Elevation Change: +1902 / -2517 ft
Max Grade: 4.6%
<iframe src="http://ridewithgps.com/routes/1870161/embed" height="500px" width="100%" frameborder="0"></iframe>
Hmmm.. I can't get the imagine to show up
Old 12-02-2012, 10:37 PM   #27 (permalink)
Doesn't do, "normal"
Project UpCycle - '01 Honda Rebel Streamliner Build
Team Streamliner
Homers Hybrid - '08 Toyota Highlander Hybrid
moms car - '97 honda accord lx
90 day: 34.93 mpg (US)
Adventure - '98 Mazda Protege
90 day: 33.11 mpg (US)
The Silver Civic - '02 Honda Civic
90 day: 36.15 mpg (US)
~6 miles to work with about equal hilling in both directions.
Old 03-02-2013, 11:52 PM   #28 (permalink)
eh.ohKate's Avatar
2012 Honda CR-Z - '12 Honda CR-Z EX
90 day: 45.25 mpg (US)
Send a message via AIM to eh.ohKate
To Work:
To Home:
To Home (Alt):
I have an alternate home route because the regular one is about 3.5 miles shorter, but it involves a much steeper gradient and in bad weather conditions (ice and snow) it just isn't safe to drive.
