Old 04-10-2012, 03:29 PM   #11 (permalink)
I don't want to argue but I don't believe they do have different versions of the hybrid synergy drive eCVT.
There is a gen 1 a gen 2 and a gen 3 system.
All versions of each generation are the same across each hybrid application.
I believe one exception to this may be the synergy drive in the hybrid civic.
It makes no difference as far as FWD or AWD/4WD to the original application because all these synergy drive eCVTs are for FWD applications.
A synergy drive in a vehicle with AWD/4WD has a seperate differential motor.
If you want rear wheel drive you could modify one of those motors.
Used hybrid eCVTS and used hybrid components in general are a great source for large powerful electric vehicle equipment.
Where else can you get a 50KW motor for $200-500 dollars?
Old 04-10-2012, 05:44 PM   #12 (permalink)
EcoModding Lurcher
mort's Avatar
Here's a neat site: ToyoDIY
You can search by car and then cross reference by part number, for a start 2010 Prius uses a 30900-47060 or 30900-47061 transmission
the 060 crosses to the plug-in Prius
the 061 crosses to the Lexus CT200H (which lists for $3,160.10)
30900-48070 or 30900-48090 Highlanders cross to Lexus RX350H ($4,125.94)
30900‑33011 Hybrid Camry ($4,290.54)
30900‑75040 Lexus HS250H ($3,409.61)
30910‑30020 Lexus GS450H (Lexus list:$16,774.68 dealer price:$5,421.47)
30930‑50050 Lexus LS600H (Lexus list:$38,579.97 dealer price:$7,242.76)
-mort
Old 04-10-2012, 06:20 PM   #13 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
-mort
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
