Old 11-06-2012, 03:05 PM   #711 (permalink)
Coroplast Engineer
slowbro's Avatar
AV - '04 Chevy Aveo sedan - not LS
90 day: 34.28 mpg (US)
Jolteon - '00 Honda Insight MT
90 day: 77.25 mpg (US)
Good for you! dead hookers always give the best traction. 100 lbs of dead hooker equals 150 lbs of lead.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
Old 11-06-2012, 07:19 PM   #712 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Yea and you can put a turbo charged chevy 350 v8 or ford 5L in it too - Monster Miata.
Corvette engine fits is a Fiero too:
- Tony
Old 11-06-2012, 07:31 PM   #713 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Planning gunmetal steelies, two long-range driving lights mounted above the grille, and nothing else. Couldn't help but to photoshop it.
Old 11-06-2012, 10:51 PM   #714 (permalink)
If it had one driving light instead of two; it would remind me [more] of my first car, a bullet-nose Studebaker.
So, leaning toward the Miata over the Festiva? I found this in my Imgur stash:
Old 11-07-2012, 01:43 AM   #715 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed
90 day: 34.62 mpg (US)
I wish there were a pre-smog miata. Those are rad cars.
Old 11-07-2012, 07:40 AM   #716 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I had a pre-miata mazda, a 72 rx2. I bought it for $100 with 60k miles and I rebuilt the rotory engine. 16 mpg was typical 18 was good. It would rev so much there was an alarm on it. Unfortunately I put the minimum clearances in the side seals and one cracked after I over revved it to 9000 rpm. To get crazy hp, all you have to do is grind the ports bigger.
Guess which one is the rotory:
http://www.youtube.com/watch?NR=1&fe...&v=aRv6smAOWAw
4 rotor engine 1991 Le mans winner, since rotary engine band from racing :
http://www.youtube.com/watch?feature...&v=bO0RSGUku-k
- Tony
Old 11-07-2012, 09:15 PM   #717 (permalink)
Sven7's Avatar
Right now I'm considering an EF HB (4spd) as well. Not sure what was different on the HB or when the VX came into existence but it wouldn't be a bad car.
But I really, really want a Miata.
Old 11-07-2012, 09:26 PM   #718 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Sir, If you want a miata then by all means get one. There is no time like the present. I was just looking at one owned by a friend this past week. Had big tires heavy springs and sway bars. Basically a gocart with plates.
My dad bought me an Austin Healy Sprite in 1969. I remember passing folks on entrance ramps with it. All the while I was using a 1/4th the fuel of the average v8.
Noah Webster, 1787
Old 11-07-2012, 09:57 PM   #719 (permalink)
Do more with less
Later on I had a 350 CI Fiero. It looked stock but rumbled.
Noah Webster, 1787
Old 11-08-2012, 08:58 AM   #720 (permalink)
Do more with less
Here is my Fiero Tony.
Noah Webster, 1787
