Old 11-30-2009, 06:33 PM   #161 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by RobertSmalls View Post
Mine does. The oil pan is completely in contact with the coroplast. I also have coroplast in direct contact with my radiator. No damage yet.
Coroplast melts at 160°C = 320°F. Motor oil is expected to be a little bit hotter than coolant, so I figure no more than 220°F.
However, I have measured my cat at 560°F, and I'm sure it gets much hotter than that.
Well, what I meant, is that after looking at AndrewJs bellypan, I noticed that he even had the Coroplast touching the exaust pipe ( header ) at the front of the car.
It looked like MetroMPG had the front exaust touching as well in the pictures, but as I look closer, it seems that he may have done the area around the exaust pipe in something other than Coroplast.
O.K. back on topic. ( the boat tail )
Old 11-30-2009, 06:45 PM   #162 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I've been working with the stuff for a long time without noticing that the minimum forming temperature is 150 C. Of the common plastics, only polycarbonate is higher, at 190.
Old 11-30-2009, 06:45 PM   #163 (permalink)
90 day: 51.82 mpg (US)
Re CAD...
What kind of software are you using
Sorry, should have said "CAD", in quotes. With a nod to Craig Vetter, I was talking about "Cardboard Aided Design".
Darin,the tuft images look great.They may be a little "nervous" in places,but they're mostly pointed "back" which means attached flow and no circulation.
Thanks for the input, Phil.
I'm a little nervous about those nervous looking side tufts. It's clear I could increase the top taper - those tufts are laying almost still right to the transom.
What I don't know - and maybe you or Bob can tell me - is this: should my goal be to taper as much as possible until I actually see evidence of separation through circulation/reverse flow, and then back off a bit?
In other words, will we achieve favorable drag results even as we increase the amount of "nervousness" in the tufts (evidence of tubulence and a thickening boundary layer) through further tapering?
It's clear I can taper the top more. Not sure about the sides though. Maybe you can decide when I post some video this week.
Many of the concept cars have "apparent" angles which are pretty steep until you figure what happens with their active suspensions,with dropped noses kicking their hineys up to a "shallower" angle.
Given that Cd is supposedly constant in the range of speeds where road vehicles operate, why would a vehicle want to actively adjust its angle of attack? Is the nose up/tail down attitude a concession to low speed driving for clearance, making the top angle aerodynamically sub-optimal until the nose goes down?
Old 11-30-2009, 06:48 PM   #164 (permalink)
In the front section, the coroplast is cut out ~1 inch around the pipe ahead of, around, and just aft of the catalytic converter.
In the middle section of the car, I've got aluminum immediately under the exhaust pipes (it touches the resonator).
Old 12-01-2009, 11:44 AM   #165 (permalink)
Due to inclement weather, CAD and further road testing will be delayed until conditions improve!
First dusting of the season. (Welcome to December!) Supposed to be warmer and the roads drier by Wed/Thu.
Old 12-01-2009, 01:08 PM   #166 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by Christ View Post
wagonman76 -
The few companies I looked into for the opportunity to use Cara for some ad space had waivers that the drivers had to sign, basically absolving them of all responsibility for damage to the vehicle whether due to advertising materials or otherwise. I'm pretty sure it's not a liability for them, really.
Well that's cool. I was just thinking that by endorsing something homemade, they wouldn't have a leg to stand on in court if something happened, as opposed to something designed by a professional company.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-01-2009, 03:28 PM   #167 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Reminds me of the lightning scene from Back to the Future:
Old 12-01-2009, 05:55 PM   #168 (permalink)
Cd
Ultimate Fail
Cd's Avatar
In other words, will we achieve favorable drag results even as we increase the amount of "nervousness" in the tufts (evidence of turbulence and a thickening boundary layer) through further tapering?
Metro, I'm assuming that the next tuft test that you do will incorporate an adjustable section on the sides of the tail.
Since you are working with CAD ( ) it would be really easy to do.
Not only will you be able to test the maximum amount of taper that you can have, but also you can verify if that flutter was indeed coming from upstream.
Old 12-01-2009, 05:59 PM   #169 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Oh wait ... I didn't think about the frame under the cardboard.
I guess you couldn't just cut an adjustable section out could you ?
Old 12-01-2009, 06:18 PM   #170 (permalink)
Right or wrong, I'd increase tapers until I see sign of turbulence, than increase until "laminar". Otherwise you may just end up with extra unneeded length. With unneeded length comes extra unwanted skin drag as noted in recent discussions re: crx and del sol tails.
boat tail, testing
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
