Old 03-07-2012, 09:26 AM   #11 (permalink)
If anybody feels like going through these to tell me if there right or wrong to build a MPGuino that would be wonderful
RJ11 - 50 x RJ11 Modular Network PCB Jack Connector 5222 6P6C | eBay
50x LCD - HD44780 16x2 LCD module Blue backlight+Free pin header | eBay
ATMega chip - 50PCS IC ATMEGA8-16PU ATMEL DIP-28 NEW GOOD QUALITY | eBay
switch - 300PCS 6*6MM 6.5MM TACT SWITCH TACTILE PUSH BUTTON | eBay
usb - 50 pcs USB-B Type Right Angle PCB Socket Female Connector New | eBay
470uf capacitor - 50 x 470uF 25V Radial Electrolytic Capacitor 8 x 12 mm | eBay
transistor - 50pcs MMBT3906 /PMBT3906/2N3906 TRANSISTOR GP PNP AMP SOT-23 | eBay
diode - !! 100pcs 1N4004 400V 1A Rectifier Diode DO-41 | eBay
oscillator - 50pcs 16MHZ 16 MHZ 16M HZ Crystal Oscillator HC-49S NEW | eBay
0.1uf capacitor- 200pcs 0.1uF 50V Ceramic Disc Capacitors | eBay
18pf capacitor - 50 Pcs 18pF 50V 20% 2mm Pitch Ceramic Disc Capacitors | eBay
1.2k resistor - 100 x Resistors 1.2K ohm 1K2 1/4W 250V 5% Carbon Film - Free Shipping | eBay
100k resistor - 100 x Resistors 100K ohm 1/4W 250V 5% Carbon Film-Free Shipping | eBay
L7805 regulator - 50 x L7805 7805 Voltage Regulator 5V 1.5A SGS-THOMSON - Free Shipping | eBay
28pin socket - 50pcs 28 pin 28pin DIP IC sockets Adaptor Solder Type | eBay
zener diode - Through Hole Zener Diode 1/2W DC 5.1V Voltage Regulator | eBay
10k resistor - 10K
220 resistor - 50 x Through Hole Carbon Film Resistor 1/4W 250V 220 ohm | eBay
50x atmega board - 1x Freeduino Arduino atmega168 Development Board PCB | eBay
only thing missing *i think possibly others* is the 'smaller capacitor... i have no idea what type that should be the yellow one that is
Old 03-16-2012, 07:25 PM   #12 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Still some mpguinos available....
Mpguino is built in custom etched PCB and is same size like LCD (sits behind it, electrically it is compatible with "official mpguino"). I am using atmega 328
Price is 59euros + shipping (4.8eur) and paypal transfer fee (depends on buyer country 3.5-4.5% + 0.35EUR).
more info and pics
I have also made custom code (based on 0.75) just like I like it
extra features:
* added metric version (must choose before code/firmware uploading, no change possible in settings)
* bargraphs (shows 2min average 5-9L/100km - dropped 0-5L to gain better resolution)
* battery voltage
* trip cost (in settins you enter fuel price)
* current trip does not reset automatically after 2min engine off. Manual reset like tank trip.
* tank trip time in hours.minutes, current trip time is now available too
* saving tank trip data to eeprom (dont forget it when disconnected)
* some values are shown in integers (speed, rpm)
* removed leading zeroes (instead "012.45" shows " 12.45")
* added dragrace screen (0-100km/h time, 400m time and trap speed, calculated horsepower)
* using Atmega chip sleep mode (consumes about 5milliAmps versus 20milliAmps when in sleep)
Old 03-21-2012, 10:10 AM   #13 (permalink)
Infiniti - '11 Infiniti G25X AWD
90 day: 29.82 mpg (US)
Compatability
Would this work on a 4.3 liter TBI engine? Will it correctly monitor a throttle body injection?
Old 03-21-2012, 05:15 PM   #14 (permalink)
meelis, would you be able to ship a unit to the US? And how would I hook this up to an aftermarket speedometer? I would think there would be a SpeedSensor wire back there
Old 03-22-2012, 04:31 AM   #15 (permalink)
meelis11's Avatar
Diesel
Hi,
I made quick search and found this page
http://ecomodder.com/forum/showthrea...ino-14552.html
more links here (use brauser search "TBI")
MPGuino - EcoModder
I dont know much about TBI so I cannot be 100% sure that it works. If TBI means that you have one injector, then it should work.
Meelis
Old 03-22-2012, 04:35 AM   #16 (permalink)
meelis11's Avatar
Diesel
I can ship worldwide (same shipping price 4.8EUR)
Speed pulses should go into speedometer - how otherwise it can show your speed?
Check your speedometer manual.
Meelis
Old 03-25-2012, 03:17 PM   #17 (permalink)
clunkergem - '95 Honda Civic VX
I am also wanting a mpguino
Old 03-25-2012, 03:18 PM   #18 (permalink)
and need 10 posts to pm you
Old 03-25-2012, 03:19 PM   #19 (permalink)
very happy that you are building pre-assembleds
Old 03-25-2012, 03:20 PM   #20 (permalink)
sorry for pseudospam
