Old 08-18-2017, 10:11 AM   #101 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
If that was important enough, I'd just have a mini radiator/heater core with a fan that stayed hooked up to the engine and hung from it's hoses in to the trunk of the leaf.
Seems a lot easier than trying to plumb one in to the leaf's HVAC system, which isn't designed for it.
The Following User Says Thank You to Stubby79 For This Useful Post:
Isaac Zackary (08-18-2017)
Old 08-18-2017, 11:03 PM   #102 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Apparently the CNG station isn't open yet.
Name: Grand Opening CNG Fueling Station
Date: August 31, 2017
Time: 11:00 AM - 12:00 PM MDT
Event Description:
Grand Opening & Ribbon Cutting & Dedication of new Compressed Natural Gas public fueling station. Dedication begins at 11:00 a.m. with speakers and ribbon cutting. Light refreshments will be provided
Old 09-03-2017, 04:52 PM   #103 (permalink)
Full sized hybrid.
Would It be alright to hook up the CNG fumigation carb/nozzle/else before the air cleaner? The problem is that the air filter is part of the plenum. There are 4 individual runners that run from it to the engine. So unless I put on four individual CNG nozzles after the air filter I can't add natural gas fumigation after the air cleaner. So for practical reasons it would be easier to just add natural gas before the diesel's air cleaner.
Here's a VW MK2 diesel air filter: VW VOLKSWAGEN 85-91 GOLF / JETTA DIESEL 1.6 Non-Turbo AIR CLEANER AIR BOX | eBay
Another idea would be to adapt an air intake off of a gasoline, perhaps carbureted VW and wire the throttle open. That way I could replace or modify the carb to something that can fumigate the natural gas into the intake.
Another thing I'm thinking is I could put on a K&N air cleaner on the beginning of the intake and put the CNG fumigation after it. Maybe the second air filter could be left since the natural gas is a gas and should flow through the paper filter element? Or I could cut out the paper element and use a filter's gasket and use the K&N air filter for the only filtering.
Old 09-03-2017, 08:46 PM   #104 (permalink)
The closer you can get to the intake runner the better with fumigation.
You don't need to add a carb to the mix. A carb would just be a restriction to a diesel.
I ran propane fumigation before the air filter years ago, only problem was some times I could smell propane. Once I relocated the injection nozzle to the top of the intake manifold, on the inside of the air filter the smell went away.
Isaac Zackary (09-04-2017)
Old 09-04-2017, 03:15 AM   #105 (permalink)
Stubby79's Avatar
I'd prefer a flammable gas/air mix to be as inside the engine as possible, just in case. Right before the manifold, if I couldn't get it in the manifold.
Old 09-04-2017, 10:54 AM   #106 (permalink)
Full sized hybrid.
Thanks! I guess I could rig it up inside the air cleaner right below the air filter.
The idea of the carb was a way to meter the gaseous fuel. I'd take the throttle plate completely out. But if there's a better/cheaper way to meter the gas I'd like to hear about it.
Old 09-04-2017, 03:02 PM   #107 (permalink)
Just use multiple nozzles, that's what I did.
Old 09-04-2017, 06:41 PM   #108 (permalink)
Full sized hybrid.
Does this look too simple?
