Old 09-17-2020, 09:55 PM   #1 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Quiz: Qualitative Flow Analysis
All right, all you armchair aerodynamicists of Ecomodder (alliterative and otherwise). Here's another quiz for you:
Below are three GIFs of tufts on the back window of a 2013 Prius liftback, taken on my cellphone taped to the trunk floor, looking up at the window. There is no antenna on the car (shark fin or wire), no washer nozzle, and no wiper. All three videos were taken at 55 mph indicated on the same section of road, northbound into a 15 mph NNE headwind.
The first GIF is your baseline. For the following two, I changed one thing--that is, there is exactly one change from the baseline configuration in each of those two videos. What are the changes?
Baseline:
Altered 1:
Altered 2:
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 09-18-2020, 01:52 AM   #2 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Are you saying 2 and 3 had a piece put back on (as in return to OEM)? Or are we just guessing a random mod?
Also there is a poll option...
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
freebeard (09-19-2020)
Old 09-18-2020, 03:47 AM   #3 (permalink)
Love the challenge, and don't mind egg on my face if I am wrong.
For reference, but no antenna on the car, no washer nozzle, and no wiper:
Baseline: Very good flow, isn't it? I'd be pretty happy with that.
Altered 1: I'd be reasonably confident you've added a fence/lip (eg a 1-inch high vertical plate or similar) that causes separation from the top of the hatch.
Altered 2: A harder one. My wife (who has watched aero testing tufts for about 25 years) says the wiper has been put back on. I say the antenna has been put back on.
aerohead (09-18-2020)
Old 09-18-2020, 08:33 AM   #4 (permalink)
Moderator
Vman455's Avatar
Yep, just guessing a random mod based on tuft behavior. I will say that both mods are moderately-to-very common on Priuschat, but to my knowledge have never been measured by anyone using them (although Altered 1 is often claimed to "improve downforce" by people who fit it on their Prius).
I thought so too. I could see some of the movement of the outermost tufts that the camera didn't pick up so well, but I'll comment on what I think is happening after I pressure test (if that confirms what I suspect).
Bingo! Almost exactly right--I taped a 21mm high lip to the top edge of the window:
Yes, this one is more difficult. There's no disruption to the baseline flow pattern, but the tufts toward the trailing edge of the window are behaving slightly differently. (Actually, now that I look again the tufts at the leading edge have changed behavior slightly as well).
The Following User Says Thank You to Vman455 For This Useful Post:
Old 09-18-2020, 04:21 PM   #5 (permalink)
Yes, could be some trailing vortex development down the pillars.
Glad I got it right! And it may well reduce lift - but at a penalty of lots of drag.
Now that I know it's a common mod, I'd suggest (un-needed) vortex generators have been added at the top of the window.
Old 09-18-2020, 05:01 PM   #6 (permalink)
Moderator
Vman455's Avatar
That's what I suspect. The tufts on the edges of the window both a) fluttered at a higher frequency and b) were "tauter" than those in the middle of the window.
I may trial some fins along the hatch edges just to see what happens.
Old 09-19-2020, 09:58 AM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
It may, but it is ruining the effectiveness of the stock spoiler so it's not certain at all.
Old 09-19-2020, 03:48 PM   #8 (permalink)
Does the rear spoiler cause much of a change in angle to the rear hatch slope?
I've never looked at a Prius with this in mind, so I am not sure. If the spoiler is just a continuation of the hatch angle (or makes it only very slightly shallower) then it will do nothing / very little to reduce lift.
Of course, if you want to get rid of nearly all lift, place a fence across the mid-point of the roof!
Old 09-20-2020, 03:13 AM   #9 (permalink)
I'd be interested in your results.
Surely someone else has tried it and reported their results, but apart from my data, I've never seen anyone else reduce drag by added long fins down each side of a rear hatch that has attached flow (and I assume, therefore, trailing vortices).
Old 09-20-2020, 10:26 AM   #10 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
What were you trying to do with the ones on your insight? Was the main goal just for something to mount the rear wing to?
1995 Mercury Tracer
