02-16-2019, 10:49 AM
#201 (permalink)
Thank you, I now understand why aircraft had a hard time going past 250 mph.
02-16-2019, 12:19 PM
#202 (permalink)
.tragectory: Line goes down and to the right.
02-16-2019, 06:58 PM
#203 (permalink)
I had to double check myself, looks like my memory is intact - for now.
https://www.grc.nasa.gov/www/k-12/ai.../machrole.html
As an aircraft moves through the air, the air molecules near the aircraft are disturbed and move around the aircraft. If the aircraft passes at a low speed, typically less than 250 mph, it is observed that the density of the air remains constant. For higher speeds, some of the energy of the aircraft goes into compressing the air and locally changing the density of the air. This compressibility effect alters the amount of resulting force on the aircraft since the aerodynamic force depends on the air density. The effect becomes more important as speed increases. Near and beyond the speed of sound, about 330 m/s or 760 mph at sea level, small disturbances in the flow are transmitted to other locations isentropically or with constant entropy. Sharp disturbances generate shock waves that affect both the lift and drag of the aircraft, and the flow conditions downstream of the shock wave. On this slide, we will investigate the dependence of the density change on the Mach number of the flow.
02-19-2019, 12:21 AM
#204 (permalink)
Originally Posted by kach22i
Might not be so comfortable to get in and out that camper module, but that looks interesting to say the least.
02-19-2019, 12:37 AM
#205 (permalink)
02-19-2019, 04:55 PM
#206 (permalink)
If that angled tailgate drops down and has steps on it's upper surface it wouldn't be too bad. You might have to stoop down.
Randy Grubb finished the Magic Bus:
Just A Car Guy: Great googlamoogla, he's finished it! And installed an elevator!
Drawing to driving in 18 months.  Aeronautical oddities:
02-20-2019, 11:10 PM
#207 (permalink)
I've liked the 1961 Chevrolet Imapala bubble-top coupe since the beginning. This example is a lift-back shooting brake.
Looks kinda weird with the rear hatch not going through the entire height of the loading bay as most of the conventional wagons used to do.
02-21-2019, 01:19 PM
#208 (permalink)
02-21-2019, 04:54 PM
#209 (permalink)
Flat beautiful. Would never have lost its appeal (had it been a production vehicle).
Virgil Exner & Son ideas for Duesenberg revival in the same direction.
The Following User Says Thank You to slowmover For This Useful Post:
02-22-2019, 09:57 AM
#210 (permalink)
This is been named the RipnRiv,
I like it, but also like the original.
1967 Buick Riviera
https://bringatrailer.com/listing/1967-buick-riviera-2/
