Old 12-04-2013, 01:51 PM   #171 (permalink)
AutoSpeed - Aero Testing - Part 4
aerohead (12-04-2013)
Old 12-04-2013, 06:02 PM   #172 (permalink)
chase car videography
Ideally,a chase car should be no closer than 30-feet from the test car,as it's presence will alter the local airflow.
Old 12-05-2013, 03:44 PM   #173 (permalink)
More fakery.
Eco Cars: Laminar 2 all-electric concept car features adjustable aerodynamics - Promoting Eco Friendly Lifestyle to Save Enviornment - Ecofriend
aerohead (04-12-2014)
Old 12-05-2013, 03:46 PM   #174 (permalink)
Not sure what I'm looking at here.
ME 439 APPLIED AERODYNAMICS SP 2007 WSU
Cd (12-05-2013)
Old 12-05-2013, 05:07 PM   #175 (permalink)
Cd
Ultimate Fail
Cd's Avatar
What a clever idea !
Put a net up with tufts just behind the car. It would show the vortex size as you see in the image. Thanks for posting !
I thought of using a cardboard 'spine-fin' with tufts sewn into it to show the flow behind my car, but I never considered a net like this.
Old 12-06-2013, 05:13 AM   #176 (permalink)
The netting idea is a good one. I looked at the Laminar [sic] 2.
The raised position is basically an open-wheeled car, which everyones says is bad. The lowered position is too bluff to create downforce, but carries a rat nest of turbulent air along. It's basically the world's worst wheelwell.
Old 12-06-2013, 07:44 AM   #177 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
Take off that front mess, and make the back the front.... like the old Thule car top carrier thread from long ago.
Old 12-06-2013, 08:56 AM   #178 (permalink)
I concur, and have to say that real wind tunnel images would bear this out.
Here are the designers thoughts.
Design website of Daniel Fitzgerald
Reduced aerodynamic drag allows us to drive efficiently, saving on fuel and emissions. Downforce, a type of drag, provides traction, allowing you to corner safely. The aerodynamics of your car is the result of a compromise between these two factors.
Laminar 2 is the second iteration of a design concept that investigates the use of a adjustable front wing system to increase a vehicles aerodynamic efficiency and down-force without a compromise on either.
The Laminar 2 concept is a blend of these two aerodynamic profiles. When its front wing is rotated down to a 40 degree angle to the road, air is deflected upwards pushing the car into the ground for safer cornering. Rotating the wing up to a 0 degree angle allows oncoming air to flow easily around the streamline cabin increasing efficiency for straight freeway driving.
Features such as driver to passenger mirrors, a central driving position and large glass cockpit have been retained. Along with some new features such electroluminescent hubcaps for night visibility, and a rear panorama camera and HUD to replace the rear-view mirrors.
Clicking on the "show more" buttons provides more.
- Adjustable wing sits on a curved bearing system, with the wing being adjusted by a series of motors for quick transitions between streamline and down force modes.
Development Notes Show / Hide
- After the completion of the first of this series of concepts, there were a number of things that worked well and a number of things that needed to be addressed. Namely complexity in the doors and front wing that were unnecessary and the open wheel format would be unsafe for pedestrians. The original concept also had unfeasibly large wheels with the front wheels running on orbital rims, which would be both impractical and inefficient in this application.
- The major change has been to the styling. As the original concept was for a competition, and styled to an existing brand, this one would have its own unique styling aspects.
It was only a styling exercise - thank goodness.
I think considering the designer's goals, air braking would have been a better direction.
Example:
Mercedes-Benz C112 | Hemmings Motor News
Click on band of thumbnails below main image.
Active aerodynamics gave additional assistance to the driver when the C112 reached its limit of traction in either cornering or braking. Sensors measuring g-forces in the front, middle and rear of the car gave information to the ECU that controlled the C112's actively variable aerodynamics. When triggered by their control system, a front spoiler and a small rear airfoil were deployed in one-tenth of a second. Combined, these created a high level of overall downforce with an inevitable increase in drag. At the car's theoretical top speed of 192 mph, they were calculated to increase downforce from an insignificant figure to around 2,200 pounds.
http://www.ign.com/articles/2007/06/...des-benz-c-112
http://www.carbodydesign.com/archive...ar-technology/
Old 12-08-2013, 12:04 PM   #179 (permalink)
Random TRANSPORTATION pictures - Page 1230 - Pelican Parts Technical BBS
aerohead (04-12-2014), Cd (12-09-2013)
Old 12-09-2013, 01:51 PM   #180 (permalink)
The “large wind tunnel” in Untertürkheim | Mercedes-Benz Passion eBlog
Lucas Adaptive Wall Wind Tunnel
