05-22-2024, 08:59 PM
Range Extender: Matching power and torque to suite the generator
This paper is interesting in that it goes into the details of modding a 250cc motorbike engine to suite the chosen generator so that you end up with a light, compact and efficient genset for your city commuter (mostly) EV, without using electronics to get the required Volts and Amps for your battery.
I like the simplicity of Serial Hybrids vs the complex drivetrain and control reqd for parallel hybrids.
Tuning and tweaking an ICE to run efficiently at a constant rpm is also much simpler than trying to get the ICE efficient over a wide rev range.
ie: The optimal cam profile, ignition timing and intake and exhaust lengths are all constant and achievable without electronic ignition and VVT etc-etc.
As grid power here in the 'New South Africa' is more off than on; Serial Hybrids also give one the option of always having house power when you get home in said vehicle..!
https://sci-hub.se/10.4271/2011-24-0085
Another link for any (2wd) bikers here, where something similar was done:
https://endless-sphere.com/sphere/th...d-hubs.110812/
The Following 3 Users Say Thank You to Logic For This Useful Post:
05-23-2024, 02:30 AM
The first one is pretty slick.
Originally Posted by sci-hub
We have detected suspicious network activity from your device.
Please verify to continue.
Does everyone see this?
.“You belong to Universe” -- the voice in Bucky Fuller's head
05-23-2024, 08:58 AM
Nope, my software won't go to or load the page. Reeks of malfeasance.
05-23-2024, 01:09 PM
Next time I go to the library I might try their computer. The 'suspicious network activity' might be the lack of Windows vulnerabilities.
I get phone calls from people who want me to go to my [Windows] computer so they can show me that it's compromised. That's exactly why I don't use Windows.
05-23-2024, 02:23 PM
High Altitude Hybrid
Link two opens. I'm afraid of link one.
Anyhow, yes, there are pros and cons to such a design. But I think as ecomodders having a simple design is of importance. No need to go crazy on it to where it's impossible to implement.
05-24-2024, 01:20 AM
One complexity with serial hybrids is, balancing input power with output power. Most mass market serial hybrids (e.g. Nissan e-Power, Honda eHEV, etc) have an electric motor providing all power driving the wheels (e.g. 150kw/200hp in the case of the Civic), while also having very small batteries (1.05kwh in the case of the Civic). These batteries can only provide maybe 20% of the motor's input power. The ICE needs to be revved up and down before the electric motor can draw power from the combined ICE + battery source, which requires very complex control, arguably more complex than a parallel hybrid.
This is a non-issue if you have a simply massive battery, able to provide 100% of the motor's peak power on its own. However, you often lose the ability to select lithium batteries optimized for capacity rather than output, reducing range or greatly increasing weight and cost.
05-24-2024, 01:41 AM
I like the concept of a through-the-road serial hybrid. Two independent systems with the road acting as a clutch to modulate the two.
It just seems simpler. You can still have regen and V2G.
05-24-2024, 10:28 AM
Suspect link talk
Originally Posted by Piotrsko
Suspect link talk
Originally Posted by Isaac Zachary
Suspect link talk
I ran the link through VirusTotal:
VT is a Google bought out organization where the said link (or file) is scanned by EVERY AV worthy of the name. Over 60 of them.
Nothing suspicious was found.
https://www.virustotal.com/gui/url/9...ce1c?nocache=1
Using IPVoid:
1: To translate site URL to IP address:
https://www.ipvoid.com/find-website-ip/
resolves to:
186.2.163.219
2: to check the IP against over 100 suspicious IP lists of millions of IPs:
https://www.ipvoid.com/domain-reputation-check/
Shows no problem.
(It'll take a while but you will learn that I, an ex netw admin
with a MCSE and BTC interests DO NOT take chances online..! )
So... at a guess; what's happening here is all the sites selling papers they get for free... can very well afford to spend some of that profit on bribing your ISPs into saying Sci-Hub is sus..!
Do take 10 mins to look up what Sci-Hub is and why it is...
Then perhaps another 5 to write your ISP and tell them to Fo Guck themselves!
The Following 2 Users Say Thank You to Logic For This Useful Post:
05-24-2024, 01:25 PM
#9 (permalink)
No doubt you're right. My only question was what is the suspicious network activity that was flagged.
What say you? Having to assert I Am Not A Robot is an impediment and there's a lot competing for my attention.
Was that intended to be reassuring?
I won't register so I can sign in just to enlarge some thumbnails.
05-25-2024, 04:22 AM
#10 (permalink)
As no-one had issues with sci-hub.ru links I put up elsewhere on this forum; heres a new link to sci-hub.ru rather than sci-hub.se:
https://sci-hub.ru/10.4271/2011-24-0085
